Question about E-Machines eMachines Desktop PC
Default gateway not available
Will not connect to wifi
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Check to make sure it has a wifi adapter. most desktops do not
Posted on Jan 29, 2015
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
How to find wpa key
You can find the wpa key by loging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi.
Start by getting the ip address of the router:
1.Press the "windows"+"R" keys (this will open the "Run" dialog box)
2.Enter "CMD" in the Run window, and press ok
3.In the Command Prompt window enter the following command "ipconfig" and press enter
4. locate the Ethernet adapter or local area connection if using an Ethernet cable. If you are using a wifi connection, you want to locate the wireless Ethernet connection.
5.Under one of those headings you want to locate the "Default Gateway" address. It will most likely be similar to one of the following: 192.168.1.1 or 10.0.0.1
6.Open a web browser and enter the address you found under the default gateway.
7.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
admin/password
admin/leave the password blank
9.Once you have logged in you want to locate the wifi/wireless menu on the page.
10.Here you will find the wifi password
Dec 05, 2013 | Computers & Internet
Where do i find my ssid on my router
Out of the box your SSID should be linksys
You can find your ssid and change it by logging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi network.
admin/admin
admin/password
10.Here you will find the SSID of your wifi network
Nov 28, 2013 | Linksys Wireless-G WRT54G Router
Everytime i try to connect to the internet it says This webpage is not available
You need to confirm you are actually connected to the internet next. In the Wifi menu that you get to by double clicking the "pc" on the task bar you will see 3 tabs. If the first tab does not have all the IP, sub-net and default gateway filled in with legal numbers then you are not connected. Furthermore if you have an "IP Address:" that starts with 169.xxx.xxx.xxx then you are not connected to the internet.
If your Wifi setup includes a security phrase then under the wireless information tab it will take the following steps: "associating with.....", then "authenticating with...." then "connected to...."
The easiest way to tell if the problem is within a Sylvania Netbook running Win CE 6 is to take it to a McDonalds or other non-secure wifi location and see if it connects.
If it connects there but doesn't connect at "home" then your problem is between the netbook and your home setup not purely a Wifi not working issue.
There is a Wifi driver update available at the www.digitalgadgets.com website as well as the Sylvania Netbook Yahoo group. There are some additional troubleshooting steps at the Yahoo group.
Tom M.
May 28, 2011 | Sylvania G-Netbook
The wireless light will not come on and I can't connect to the internet
By default the wireless function of this gateway is on, check if you can find the SSID using your PC. Default ssid of the gateway is always 2WIREXXX where the xxx are the last 3 digits of your Serial number
If you can't detect the wifi, open the GUI of the router and configure wifi inside it, you will need the system password to get in. you can find the system password on the gateway. look for the sticker.
Feb 21, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot connect to wifi in psp
Hi zablancruzma,
To be able to connect your psp wirelessly you need to know the settings of your router. I've listed the steps on how to get the information on your router and Connecting your psp to the internet.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
How to connect your PSP
1. Open Psp
2. Go to Network Settings
3. Go to Infrastructure Mode
4. New Connection (then select available connection)
5. Under Wlan Setting choose Enter Manually or Scan your SSID
6. SSID (Select your SSID)
7. Wlan Security Setting (WEP/WPA/WPA2)
8. Enter you Network Key
9. Test Connection Settings
and lastly Rate me if this helps so i can help others.
Thanks for using Fixya.
Jan 31, 2011 | Sony PlayStation Portable (PSP) Console
When I try to connect via my home wifi network, the error message "No gateway found" appears. I have put in the WEP key.
You would receive this message when you are trying to connect to a wifi network if any of this is the problem;
1. The wifi network you are trying to connect to has a connectivity problem and hence you are having that error message.
2. The wifi is available but has not connectivity to the internet.
Sorry this possibly means that your home wifi network has some problems.
Regards
Aug 16, 2009 | Nokia E71 Smartphone
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Voyager A210 Laptop shows when connected to wifi "Limited or no connectivity"although others are connected on same router at the time. I have removed wifi program and reinstalled No difference
This is just a try. Find out the Default Gateway on the other computers. If they are using a static IP then you need to get on. At someone else's computer click Start and Run and enter Cmd and click OK.
Now type in ipconfig /all. Look for IP Address, Subnet Mask, Default Gateway and DNS Servers. Write it all down. Then find an available IP address by using the Ping command.
In the same Window, type in ping and the IP Address of the computer you are at. That's just to show you what it looks like when you find an IP already taken. You'll see "reply from..." with the address you just pinged. Now ping again but change the last octal in the IP (the last number) in the IP address to something under 256. And ping again. Do this until you get a message "request timed out". You've just found an available IP.
Mar 27, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
