Question about SUMMIT Professional FF1615SS Refrigerator
Is there a fan in the fridge part of the fisher paykel refridgerator model E440 TRE
I found the fan in the freezer part but not in the fridge.
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
Mar 31, 2015 | Fisher Refrigerators
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Fisher & Paykel Model #E522BRX Fridge portion not working but Freezer OK
Hope I'm not too late - I had EXACTLY the same problem and the freezer fan wire was broken. I fixed it an documented everything in http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf. Good luck.
Aug 14, 2008 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
22 people viewed this question
Top SUMMIT Professional Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a SUMMIT Professional Refrigerator Expert? Answer questions, earn points and help others
