Question about Broan-NuTone N-RF69NR Attic Fan Attic Fan
RF-69nr where do we buy RF-69nr motor for NUToneattic ventilator
    Scholar:
  • 95 Answers
The motor sells for about $140.00. I would check here https://www.centralvacuumstores.com/fan_help.php
or here http://nutone.com/
Posted on Jul 01, 2009
What are the step by step directions for finding out where blowing motor is and how to replace it in a 2003 buick lasabre
Before buying a blower motor, check the heater fuse, blower motor relay by swopping it with the same type and check for power at the blower motor when its should be on. If there is power and ground at the motor and it doesn't work, then you can condemn it.
  1. Remove the right side sound insulator in the passenger compartment.
  2. Disconnect the electrical connector from the blower motor.
  3. Disconnect the blower ventilation tube from the module.
  4. Remove the blower motor screws.
  5. Remove the blower motor from the housing.
  6. Install the blower motor into the housing.
  7. Reverse order to put everything back.
Nov 29, 2013 | Cars & Trucks
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Where can I buy a new motor for 20 year old # 3C453 Dayton attic power ventilator: Motor is 1/35 HP, 1350 rpm, 120v, 0.9 Amp, Tag on fan says use #7163-3487 motor. I can't find on internet. Thanks, Carl
I have never heard of a 1/35 HP. However Tractor Supply or a Farm and Fleet Store may carry that motor. If you get the right Rpms, volts and close on
amps, then you only have to worry about the shaft size.
Jun 24, 2010 | Heating & Cooling
I HAVE A 99 Suzuki Escudo 2.0d RF-Motor. How much OIL?
A typical Mazda RF Diesel Engine requires approximately 5.5litres of engine oil if the engine oil filter is replaced as well.
Mar 13, 2010 | 1999 Suzuki Vitara
My nutone attic fan 69nr does not turn on
Hello
Check power from the t-stat to the motor or relay depending on how yours is configured for control voltage. If power is present at the motor. You will need a meter that can read amperage, take a ampdraw on the leads of the motor. See what this reading is, on the motor there should be a rating for LRA (locked rotor amps) if the amp draw exceeds this reading your motor is bad. You may also have a split phase capacitor installed which helps start the motor is so and you have a meter that reads in micro farads you could check the capacitor. the symbol for mico farads looks like a uf. Just make sure you discharge the capacitor to ground with a screw driver or insulated tool, if not it will shock you severly. Another thing you might look for is a reset button on the motor. Most likely this will be a red button somewhere near the bottom side of the motor.
May 29, 2008 | Broan-NuTone N-RF69NR Attic Fan Attic Fan
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Dryers Logo
238 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
