Question about Home
Repair reginox tap
Hi, I'm unable to use a allenkey to open my kitchen sink tap.pl help.
    Sergeant:
  • 384 Answers
Try a small screw driver put some CLR in the threads good luck
Posted on Jun 01, 2014
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Can i drill a second hole for a second tap in a composite sink please
On all the composite lav. or kitchen counter top materials that I'm aware of you can drill holes as needed using hi-speed bi-metal hole saws.My advice is to just go slow to make sure you start straight and be extra careful when the hole saw is finishing hole to avoid rough edges. I hope this helps you. Thanks. It would be a good idea to wear a dust mask to avoid inhale dust.
Jan 14, 2011 | Astracast ACR1919AP Rok Composite Kitchen...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Kitchen sink leak
Hi
Where is it leaking from? is it a single spout/mixer tap?
Please verify, and i should be able to help you
Thanks
Steve :o)
Jul 17, 2009 | American Standard Home
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Mixer tap on the kitchen sink
Hi gt_elijah.
I'm Harvey the Master Plumber.
You want to know if there any way to tighten a faucet on a kitchen sink?
Yes! All faucets have to be secure, but there are as many diferent methods as there are diferent manufacturers. If you are unfamiliar with the diferent methods then you might not recognize the screw, nut, bolt or fitting when you look at it. Also, for many, a special tool is required. It might be wise to have someone local look at it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 04, 2008 | Plumbing
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
