Question about Video Game Consoles & Games
Llooking for hose burst valve sanderson teleporter manual
Looking for bust hose valve
3 Suggested Answers
  • 91 Answers
SOURCE: vacuum hose busted
Sounds like the computer system readjusted it self to the specific air measurements that the busted hose was allowing in to the engine.(This is only relevant if you have a 1987-up) turn off the car, remove the battery cables, and let sit for 45 min, this is ample time to reset the computer memory. Reattatch cables and start. It may run rough for a few miles but if after say 50 miles of driving, if it still wont idle, than you may need to replace sensors. (MAF, intake sensors, O2 sensors, etc..)
Posted on Aug 03, 2008
  • 172 Answers
SOURCE: SANDERSON TELEPORTER,
Perkins is a hard engine to prime. Fill the fuel filter with clean diesel, there should be a hand pump on the left side(looking at the front of the vehicle) . There should be a bleed screw on top of the filter housing. Loosen the bleed srew and pump the hand pump untill you get a steady stream of fuel from it. Tighten the bleed screw. Loosen the injector bonnet nuts approximately 1 1/2 turns on all of the injectors. Turn the engine over until you see a steady stream of fuel from the the injector bonnets. Tighten the bonnet nuts, pump the handpump approx 10 times and start the engine. Give it half throttle until it stops stumbling and all of the air is worked out of the system.
Posted on Jan 09, 2010
Everything works but no water coming through into machine. Water pipes are full of water and valve is open
make sure you don't have hoses that require water to flow in a certain direction, look for an arrow that indicates proper direction, also, turn the supply water valves on very slowly because some "anti-burst" hoses will lock up if they are hammered by water. Are the water inlet valves on the machine receiving 120v when it should be filling?
Apr 23, 2016 | Washing Machines
Why does my pressure hose burst when I use a turbo nozzle
Turbo heads are pressure rated for different pressure washers, your turbo head is most likely rated bellow the maximum pressure of your washer which in turn causes a pressure build up in the hose and it's eventual failure.
Sep 24, 2014 | Honda Pressure Washer PSI 3000
Radiator top hose busted now there is noise in engine, sounds like water got in engine through intake or plugs got wet/ wiring. draining oil looking for water in it. If water in oil and now a noise were to...
no be carefull and dont play with something you dont understand ,noise could be the plastic impeller on the waterpump drive shaft come adrift causing the engine to overheat and burst the pipe and the noise is the impeller loose inside the block housing
Sep 27, 2013 | 2007 Dodge Charger SRT8 Sedan
2002 bonneville coolant leak
check water pump hose and the pump. a clogged thermostat can cause pressure build up and bust hoses. and of course take radiator out and check for lower hoses and crackes. if no luck, put water in radiator and run car and check for leaks. small cracks in aluminum are hard to see but expands when radiator gets hot.
Jul 14, 2013 | Cars & Trucks
I have a Bosch aquatak 120i the motor keeps running all the time
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Feb 19, 2012 | Garden
Leaking handgun karcher k785
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. !!
98 Ford power steering keeks bursting the high pressure hose.
it sounds like it is pumping too much pressure, you need to take the vehicle to a power steering specialist & have the pressure adjusted otherwise you will just keep bursting hoses or the seals on the steering rack......hope this helps.....cheers.
Jun 28, 2011 | 1998 Ford Windstar
Power steering pump return line hose keeps busting. why?
Was it replaced with the proper type of hose? If your using a generic hose it may not be able to handle the pressure of the pump and it could cause it to burst.
Jan 03, 2011 | 2001 Chrysler Town & Country
I ahve a 1989 sanderson 725 teleporter and am having difficulty setting up the brake cylinders. There is two one abouve the other that are attached to a pivot system. But I cannot seem to get them set so...
same back brakes as a ford D series by the sound of it ,if you can take some low resolution pictures and upload them for me so i can if their the same girling type brakes i can then tell you how to set them up ,they have two pushrods that go inside the shoe and have a cantelever mechanism that is adjustable ,the setting is 10th clearance or a small wiggle woggle and both these rods are the same size .see how you get on and if need be let me see them ,i havent been beaten yet by any vehicle manufacturer
Oct 31, 2010 | 1985 Mitsubishi Pickup
SANDERSON TELEPORTER, HOW DO I BLEED THE LUCAS FUEL PUMP ON A PERKINS ENGINE
Jan 08, 2010 | 1985 Mitsubishi Pickup
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
