Question about Memorex Office Equipment & Supplies
Memorex sts71e the dvd door won't open or close and there is no disc stuck in it.
SOURCE: dvd burner door stuck open
Hey Even i am facing the same problem.
I wrote one DVD-R.. then i inserted it to check it.
I got stuck inside. I just purchased a new Moser baer LITE-ON DVD Write two weeks back.
wat shall i do,.. Plz help me.
Posted on Feb 26, 2008
SOURCE: My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Posted on Jul 06, 2008
SOURCE: DVD is stuck in Disc tray, will not open
I have a Phillips DVDR3390/37 and was getting a BLOCKED message. I found that by utilizing the slot on the bottom of DVD and moving the mechanism slightly to the left, it would open the DVD tray. The white plastic you see through the slot is part of the motor driven mechanism that raises the DVD disk up to the drive wheel that spins the DVD. The opening and raising actions are interconnected mechanically. I suspected the motor was going, so I unsoldered its black and red wires fom the small printed circuit board and removed it by also removing the two small screws on top. The board has a + mark and this is the red wire, remember which wires go where. (Might not be red and black.) I tested the motor with a flashlight battery and it seemed to run OK but didn't spin very long. This is a very small motor without a lot of reserve power. Removing it allowed me to oil the top bearing, the only one you can get at, as the bottom bearing is not open. You don't want oil all over the pulleys and the rubber band that rides in the pulleys and you have very little room to get the oil in under the plastic pulley. I used automatic transmission oil, a fine lubrican for a lot of things. This only takes about 1 drop of oil. If you get oil on the pulleys or belt, clean them with alcohol. This procedure fixed mine. Hope this helps.
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Posted on Sep 04, 2009
Memorex cd/dvd player won't open. I can't get my dvd out
It may be necessary to disassemble your player to get access to the drive for removal of the stuck DVD.
Jun 18, 2016 | Memorex Mvd2047blk 1080p Hdmi Progressive...
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
DVD is stuck. open close button does not work. Is there a solution to this problem?
yes..... you need to unplug (power) the player for 10 - 15 mins... plug back into wall, but when you do this press the stop/open/close button (because the player will try to load the disc).....
good luck
Jan 21, 2011 | Memorex MVD2042 DVD Player
I have a portable memorex dvd and when I turn it on it says dvd open. but its not open?
There may be something wrong with the sensor on the door latch. We suggest lightly pressing on the door latch to see if the message goes away. Place a disc in the player. Use extremely light pressure initially when the disc is first placed in the drive and the door closed.
Gradually increase pressure very slowly. If the issue is with the latch and sensor, the disc may spin and the message may go away. If the unit is within 90 day warranty, then Memorex or the retailer can replace it. If past warranty period, the door may be repaired at a local repair center.
Aug 06, 2010 | Memorex MVDP1077 Portable DVD Player
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Top Memorex Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
