Question about Browning Theftgard Gun Safe
How to reset gun safe combination
Reset combination
I need the preset combination for gun safe
you posted in cars and trucks, but I'll help with what I know..
Try 159#, 159*, 195#, 195*. The electronic combinations I believe reset to factory preset number which I believe is one of the 4 numbers above I just can't remember which it is.
hope this helps you.
let me know
Dec 31, 2017 | Cars & Trucks
Set combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
Browning Theftgard Gun Safe Logo
109 people viewed this question
Top Browning Home Security Experts
Lawrence Oravetz
Are you a Browning Home Security Expert? Answer questions, earn points and help others
