Question about LG Electronics Lg Tone Hbs-700 Bluetooth Stereo Headset - Hbs 700 Behind The Neck
How to reset hbs700
Blue circle stays lit and does not connect even after successful pair
How do i connet my lg hbs700 from my old fone to a new fone?
Turn the bluetooth radio off on your old phone. Turn on the hbs700. Your earpiece should automatically go into pairing mode when it does not detect your old phone. Turn on the bluetooth radio on your new phone and search for your hbs700. Connect to and you're done.
Feb 25, 2015 | LG HBS-700 Bluetooth Headset
I have a samsung wep 450 and lost the phone it was paired with, is there a way that i can rest my blutooth so i can pair another phone to it?
In order to pair your headset with another phone you have to put the headset into pairing mode. You can do this by: Turning off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. Search for and pair with your phone according to yourphone's user guide. (Bluetooth PIN: 0000, 4 zeros) If the pairing is successful, the blue indicator light willflash 10 times rapidly before entering Standby mode. If the blue indicator light remains lit, retry pairing.
Jul 15, 2011 | Samsung Televison & Video
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Have a new motorola bluetooth h17. it pairs with the ps3 but wont connect, just error 8001000c. i even changed the audio settings to match the device and still wont connect
pairing motorola h17 with Ps3. Go to settings then to manage bluetooth scan find bluetooth (enter passcode 0000) hit triangle connect.(only first part keep reading) Now go to audio devices section under settings and change imputs to the motorola h17. If you don't go to audio devices the bluetooth wont stay connected. It will connect for like a second and stop.This drove me crazy for a day until I discover the fix. now go back to manage bluetooth and connect bluetooth and it should stay connected > you will see blue circle.
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
• Turn off your headset and press and hold the Multifunction
after blinking.
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
Jan 03, 2010 | Samsung WEP350 Bluetooth Headset Red
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
LG Electronics Lg Tone Hbs-700 Bluetooth Stereo Headset - Hbs 700 Behind The Neck Logo
26 people viewed this question
Top LG Electronics Radio Communications Experts
eradiostore
eradiostore
Are you a LG Electronics Radio Communication Expert? Answer questions, earn points and help others
