Question about Supersonic IKONVERT Digital TV Converter Box
Was watching tv and just quit working
Can not get it to power on
Plasma model 60pv250. Have sound, but why no picture?
Quite possible, plasma are notorious about power they over heat tremendously, So quite possible is the power board, its really hard to pin down in a plasma, you are stuck in buying extra parts just to see if it works. i had 2 and the power supply didnt help, but good luck in your adventure it is a learning experience
Dec 15, 2015 | LG Televison & Video
Seiki LCD TV no activity at all when power button pressed. Would replacing the main board fix this? Can that be done by an average person without soldering?
Hi Steve,
Before changing the main board for a dead TV there are quite a few things to be checked. First of all the main cord, then the fuse on the power board and then the power board. In your case please check the fuse on the power board and replace it with the same rating. If the TV starts working, enjoy watching and if the fuse blows again, consult some TV Tech.
Jun 30, 2015 | Seiki Televison & Video
Toshiba 42" hdtv just quit
chec the power point with another electrical item... perhaps the plug has triped.. if ok i think it will be your main fuse inside the tv
Jun 22, 2013 | Televison & Video
I was watching my LC320EM2 32" LCD and it quit working. It's only a yead old . The power plug and receptacles all checked out OK. Any ideas?
It sounds that the main power supply regulator board to your TV has damaged. There is no repair to these boards. Only replacement can be done. Contact any experienced service technician. This is not a user reparable work.
Dec 27, 2012 | Emerson LC320EM2 32" LCD HD Television
TV quit working when watching it, power light flashes red six times when trying to power on?
6 times blinking red light shows problem of missing DD 6Volts in G1 (power supply) board.
Please replace G1 board in tv to solve this problem, part number of G1 board is as follows..
A1060177A
Thanks.
Feb 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Mitsubishi TS-50611 projection tv has no video
You can do quite a bit to narrow things down....
First thing, unplug the set and wait 10 minutes. Then plug it in and watch the green power LED. If it does nothing push the power button and watch the power LED. If the set doesn't respond hold down the MENU and INPUT buttons on the front of the set until the LED starts blinking. If it blinks at this time count the blinks and then repost.
May 26, 2009 | Mitsubishi TS-50611 50" Rear Projection...
TV made a loud popping sound and quit working
Bad IHVT ( transformer ) = Part # 239111 use original only, no cheap subs !...............T.
Oct 02, 2008 | Proscan PS50700 50" Rear Projection...
Supersonic IKONVERT Digital TV Converter Box Logo
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
