Question about Supersonic IKONVERT Digital TV Converter Box
Wont power on
Was watching tv and the converter box just quit working
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
How do ihook up to a second tv from ikonvert digital box
your going to either buy a share, Y-cable to run both tvs, or switch box to select the tv you want to watch a that time
the connector on the tv has to match the connectors on the converter box.
just remember you will be watch same channel at the same time
you could also leave everything hooked up, than get Y-connector and put on the output of the box run line to each tv your still be watching the same channel without doing a lot of work and time
Mar 10, 2015 | Supersonic IKONVERT Digital TV Converter...
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Converter box worked fine and now wont get any signal
Did you go through the complete setup by putting your TV on Channel 3 and letting it scan all of your channels or are you just hooking up the box and not doing this? Make sure the box is set to "blue" which is On and do the complete setup.
Nov 18, 2008 | Zenith C27A24T 27" TV
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Jul 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
Supersonic IKONVERT Digital TV Converter Box Logo
53 people viewed this question
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
