Question about Hayward Industrial Products Aqua Rite Electronic Chlorine Generator 25K Gals. w/T-CELL-9
Power and Generating lights come on but both shut off after about 30 seconds
Cell does not apear to be producing chlorine
What is wrong with my Aqua Rite Electronic chlorine Generator.
when unit goes off see if voltage from transformer if not bad transformer if os bad cell and sensor
Sep 09, 2016 | Hayward-Goldline Aqua-Rite Electronic...
Hayward rp30 salt chlorinator
You should get a new one
Feb 25, 2014 | Pool & Spa
Turbulent flo control
check chlorine of pool and then test at 1st return chlorine should be higher your chlorine m ight be locked and eating up the chlorine your generator is producing also check for phosphates in water or other contaminates
Feb 19, 2014 | Pool & Spa
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
Zodiac LM3 24S won't turn ON
Two Things come to mind, the board, or it could be that the life of the cell has expired.
The Pool Tech
Jul 13, 2009 | Zodiac Duo Clear System Chlorine...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Jun 04, 2009 | Jandy AQUALINK RS TELELINK KIT
Hayward Industrial Products Aqua Rite Electronic Chlorine Generator 25K Gals. w/T-CELL-9 Logo
13 people viewed this question
Top Hayward Industrial Products Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Hayward Industrial Products Electrical Supply Expert? Answer questions, earn points and help others
