Question about Amana NED4600YQ Electric Dryer
Replace heat coil
How to get to tje heat coil
I changed my water pump on my audi a4 1998 I broke this thing in the blue now I have no spark any ideas what it is and if this would cause the no spark problem
If you have no spark after you broke whatever it is. I can't tell what it is by tje picture. But it sounds like it's the input for the coil packs (map sensor) maybe somewhere down that line.
Nov 10, 2014 | Cars & Trucks
Outside compressor and fan stay on
Hello, the relay/ contactor coils will be located in tje control panel of the outside unit. You can follow the the wires from the disconect box into the unit, it will lead directly into the relay/ contactor. When both the fan and compressor run nonstop even when thermostat is satisfied the the contactor is welded and must be replaced.
Jul 24, 2012 | Heating & Cooling
Water is leaking from the evaporator pan beneath the coils down the inside heater wall and onto tje floor. The condensate pipe is clear. The pan is not accessible within the sheet metal box sitting above...
Hello, if the condensate pipe is clear then most likey the pan is cracked, onlynway to acsess thenpan is by opening up the plenum by cutting into it with sheet metal tools.
Aug 22, 2011 | Goodman Heating & Cooling
When i turn the air on it will not get cold at all, someone mention i could have a leak where the freeon goes.. what kind of problem could this be and how much is the cost of fixing it?
Hello, it could very well be a leak, if the air filter, evap coil, and airflow all seem ok then i would suspect a leak. Depending on where it leaks will depend on how much it will cost, if it is just a leaky schreader valve core then the core is just replaced and freon is added to the proper level. This would be somwere in the 100-150 dollar range. However, if it is a leak somwhere in tne lineset or in the evap coil then the leak must be repiared, a vacuum pulled on tje unit, nitrogen added, and finnally freon chraged back in, this would be closer to 400 dollar range. I hope this helps
May 18, 2011 | Heating & Cooling
My air conditioner will not run, the fan will not run in auto or in run mode, the compressor will not start. The thermostat clicks on but the air unit does not. this is a Goodman cplj18-1b unit.
Hello, if the outside unit is not running check tje power supply to make sure you are getting 240 volts, also make sure the contactor coil is receiving 24 volts, if you are not getting 24 volts at the contactor then it may be a bad thermostat, control board or the thermostat wiring is loose or perhaps cut somwhere. If you have 24 volts at the contactor and does not energize than replace the contactor coil.
May 12, 2011 | Goodman Heating & Cooling
My 02 ford escort is over heating, and starts running really rough and knocking before it wants to quit running. What could this be?
It starts knocking because the engine is getting hot. If you have an electric fan, check to see if it is working. If it is working, replace the thermostat. Last check to see if you have water in your oil Tje oil will be a milky color. If it is you need to have the head gasket replaced. I hope this helps you.
Nov 29, 2008 | 2002 Ford Escort
Amana NED4600YQ Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
