Vulcan oil heater smokes on lighting
We have an old vulcan oil heater which has been reliable for many years but lately it sometimes smokes badly when it is lit. Any clues?
SOURCE: vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Posted on May 05, 2008
stephanos18
  • 144 Answers
SOURCE: i have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
Cheers
Posted on May 30, 2009
shastalaker7
  • 1515 Answers
SOURCE: Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Posted on Jan 19, 2010
SOURCE: Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Posted on Jul 12, 2010
SOURCE: just installed a vulcan oil heater, but when you
Sounds like you may have the wrong size tip on your oil burner. A yellow flame indicates too much fuel not enough oxygen.
Posted on Jun 12, 2011
Kawasaki problems
A 4 year old bike is too young for those kind of problems.
I would not fiddle with it, let a service tech do it. Bike is too new for driveway hack fixes.....That's just how I feel.
Aug 13, 2014 | 2010 kawasaki Vulcan 1700 Voyager ABS
Oil burner late ignition
I would check the spacing between the two probes. If they are too far apart they will not generate wnough heat to ignite the fuel. Or the porciline in the igniters could be cracked and grounding out sometimes, or the air fuel mixture could be off a bit, you may have to adjust the input air Good luck
Sep 08, 2012 | Heating & Cooling
Where can i get heating filter (ceremic?) replacement parts for an old vulcan heater?
Do you know the model heater?
Can you post photo of the filter?
I have some filters for Vulcan oil heaters
Aug 18, 2011 | Vulcan AUW230A Heater
Just installed a vulcan oil heater, but when you start it up it will only burn yellow flames and keeps going out and will smoke, then relight with a bang,
Jun 08, 2011 | Heating & Cooling
Trouble starting an vulcan oil heater
Are you able to post a picture/photo of the heater. I may be able to give lighting instruction.
where are you, I'm in Adelaide SA
Oct 25, 2017 | Vulcan AUW230A Heater
Hi ddsalm,
Jun 22, 2010 | Heating & Cooling
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
