Question about Harman Kardon HK 3480 Receiver
What is the amps on the 250mv fuses
250mv fuses are blown in 3480 want to know what amp size are these fuses
I'm running 8 gauge wire for battery cable and ground cable....my amp.is a momentum 600 watt...2 channel. ....my fuse is blowing every time I hook up either cable...
First of all, what size fuse? Check the amp and see what max amperage is, and insure your fuse is that size. Secondly, I suspect either a blown speaker or blown outputs. Disconnect the speakers from the amp and see if the fuse still blows. If it does, either you are hooking two wires up improperly, or your outputs are toast.
Aug 06, 2016 | Car Audio & Video
Jandy Lite 2 LJ pool heater FL4 Fuse amp size
if blown they are 220 volt 3 amp you can also remove them
May 20, 2015 | Jandy Pool & Spa
What fuse controls the blower motor and cigar lighter
You people need to list the year, make, model, & engine size, when asking a question. It helps when we know which vehicle it is.
All I can tell you right now, is take of the cover to the fuse box, it should be marked on the inside of the cover. If not & your blower motor & cigarette light are both not working & you suspect a fuse,
you will need a test light, clip it to a good ground, then with the key on (motor off) touch the little metal taps that are on each side of where it states the size of the fuse, the test light should light, when you touch each tab, if it only lights on one side, then that means that side is the hit side & the fuse is blown preventing the current from traveling to the other side to feed the power to whatever circuit your testing. One you find the blown fuse, you can pull it & see it's blown
Jan 06, 2015 | Cars & Trucks
What size glass fuse do i need to relace one in my warfedale 5000 amp
more than likely its a 30 amp fuse but if you look at the old fuse it should tell you the fuse size
Sep 19, 2014 | Audio Players & Recorders
What size is the fuse for the cigarette lighter for a 2004 Saturn Ion
You need an owners manual for fuses & lamps
If you find the location --you have the size
If you look at all the fuses-- you eliminate the question
& if a fuse is blown
This is just a chat room,sorry, don't have any data here,at
home like you
Nov 26, 2012 | Cars & Trucks
Blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Dec 28, 2008 | Dahlquist QX-4A Main / Stereo Speaker
Blown fuse inside tv
Look at the fuse you pulled out. The rating is embossed on the side or end.
Dec 28, 2008 | Apex Digital AT2008 20" TV
No speaker sound with hk 3480.
your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
Nov 20, 2008 | Harman Kardon HK 3480 Receiver
HK 3480 sound suddenly cuts out
May 23, 2008 | Harman Kardon HK 3480 Receiver
Blown fuses
I used to have one of those amps also (nice amp btw) Did you try another fuse of the same size?
Is it blowing fuses everytime you put one in or did it just blow that one fuse ?
Is the conection on the battery solid and clean of corrosion build up? Because that is a good amp and if wired properly shouldnt blow out or anything and so if the speaker is not blown then maybe connection is weak somewhere? I would try disconnecting the speakers from it and try a new fuse and if it does not blow the new fuse than amp is ok? and if it does blow the new fuse right away then there must be a short somewhere in the wire or the amp. then disconnect the fuse again and reconnect the speakers and if the fuse blows with the speakers connected but doesnt blow with them disconnected then you know it is a blown speaker causing the problem.
Just currious but what size fuse do you have connected at the battery?
Jan 06, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Harman Kardon HK 3480 Receiver Logo
18 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
