Question about Sharp LC-70LE847U 70 inch 240hz Wifi AQUOS 3D LED TV [LC-60LE847U]
Sharp LC60LE847U fuzzy snow
No picture showing
Fuzzy picture on laptop computer
Have it checked in service. It could be the inverter. Or first you can uninstall video drivers, restart, and install the latest drivers.
Apr 17, 2013 | HP Pavilion Computers & Internet
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
I will to know the code for the precision Tv
Hi, I have a sharp 32sf56b. sound OK. Picture went dim and fuzzy. Clears up a little when turning brightness control all the way down. Picture has no snow. Can see fate vertical line on screen
Mar 08, 2009 | Televison & Video
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Feb 21, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
Fuzzy pictures
Go back to film. Digital SUCKS.
Dec 21, 2007 | Casio Exilim EX-Z50 Digital Camera
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-70LE847U 70 inch 240hz Wifi AQUOS 3D LED TV [LC-60LE847U] Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
