Question about Diamond Multimedia ( VC500) Video Capture
Ezgrabber doesn't open
Program stops working
What software works with ez grabber video cap device
I've had success with Pinnacle 9 a few years back also Ulead Studio 11
Sep 03, 2017 | Mygica Ezgrabber Video Capture Adapter...
Diamond VC500 no video formats and black screen, not recording
Had this exact same issue, tried uninstalling, reinstalling, unplugging, plugging back in, updating drivers, etc. with no success, but it was all resolved instantly when I switched the device to a different USB port. The port I was using before works fine (in fact my keyboard is now connected to it as I type) but maybe it is a different type of USB port, and not the one the video capture device is looking for. Hope this helps others with the same issue.
Jan 08, 2012 | Diamond Multimedia ( VC500) Video Capture
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Ulead Video studio 11 in Vista
it will change the firewall settings . please stop the use of this software..
Sep 12, 2009 | Ulead Videostudio 8 for PC
I want to transfer from vhs to dvd. Video tape is protected.
You can copy VHS tapes that cannot be done on standard equipment. You can buy EZGRABBER to down load VHS tapes to your hard drive, then use a program likePower Produucer to go from your hard drive to a recordable DVD unit if you have one installed in your computer
Apr 21, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Nov 23, 2007 | Symbol MC1000 Barcode Scanner
Diamond Multimedia ( VC500) Video Capture Logo
67 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
Lawrence Oravetz
David Gust
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
