Question about Echo Backpack Blower PB-500T
Will not idle with chock off
Cannot accelerate
What is the ignition timing for 2002 nissan hardbody 2000i 16v
Here are the 3 engines listed for this year. IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 2.4L SFI 4cyl
The Ignition Timing
18-22 DegreesBefore top dead center - When throttle positionsensor disconnected and using suitably programmedscan tool.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (750-850 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (700-800 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI SC 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chockdrive wheels, curb idle speed (700-800 RPM)transmission in neutral.
Jun 05, 2015 | Nissan Hardbody Cars & Trucks
Lacks power as you push throuttle down
Robert Knorr: Check your Air Filter, may be clogged with oil or dirty. chocking off the air . idle is ok need less air. acceleration need more air , can't be done..bigAl
Apr 19, 2014 | 1993 Dodge Shadow
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
Toyota hiace 1982 18R motor not starting when cold
Sounds like the automatic choke is not functioning properly. Take off the air cleaner before starting on a cold day. Looking into the carburetor, the round choke plate should be nearly closed. If not, check the linkage to see if it is disconnected or hanging up on something. If it is OK, look down the carburetor with the chock plate held open, operate the throttle linkage and see it it shoots a stream of raw gas down the carburetor. If not, the accelerator pump will need to be replaced. That stream of gas aids in starting when cold and in acceleration (as opposed to a gas in mist form that it idles and runs on). An accelerator pump is included in a Carburetor kit and usually looks like a round flat rubber diaphragm.
Oct 30, 2013 | Cars & Trucks
My ttr 125 will start and idle with the chock on, but as soon as I shut off the chock it dies. It will also run if I set the idle set screw all the way up, but only for a short period of time. Could it be...
The jetting is fine as is. The carb just needs to be cleaned. The pilot jet especially and the related circuit as well. Go to the website below and you can see an exploded view of your carb. Please rate my answer. Thanks.
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
Sep 04, 2010 | Yamaha TT-R 125 Motorcycles
The engine idle ruff and i have no power when eccelarating
fuel filter chocked up ,clean out,, exhaust chocked ,usually the cat is bunged up so too much back pressure ,so engine cannot develope power properly cat change needed
Jul 09, 2010 | 2002 Chevrolet Monte Carlo
1993 oldsmobile cutlass supreme engine stalls choking
soundl like idle air control valve sensor
try a clean .............if no better replace
Apr 30, 2017 | 1993 Oldsmobile Cutlass Supreme
94 mazda626 v6
sounds like faulty cam shaft or crankshaft postioning sensor, or could be simple timing problem check belt positioning and allignment marks in repair manual if correct check sensors (details in troubleshooting section of repair manual) if still stumped either buy a OBDI scanner and have at it easy to use, or take it to a shop with OBDI diagnostics. also sometimes even a faulty oxygen sensor can do that, or air mass sensor ut to be sure scan it!
Jul 11, 2008 | 1992 Mazda 626
Echo Backpack Blower PB-500T Logo
149 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
