Question about Kenwood KAC-8103D Car Audio Amplifier
On my kac8103D kenwood amp the red light stays on
Red light stays on
I have a kenwood subwoofer, the red light comes on but I am getting no sound, help?!
red light is usually bad like protection mode unless it is supposed to be red. amps are always green and red is protection indicator normally. look it up for your amp and if you bought it used you got ripped off
Mar 14, 2015 | Kenwood Car Audio & Video
Kenwood kac-9105D amp
Tipical for that amp.Did you buy it used?
Oct 27, 2012 | Kenwood KAC9105D Car Amp
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
Red and blue light stays on but it cuts on and off, what's the problem? It comes on and works but the red light stays on along with the blue light..when the speaker cuts out, it acts like its trying to...
hi there
The reason for this is the ground is weak to the amp make sure that the post that your ground wire is screwed down to is tight also make sure that is touching bare metal if there is paint on bottom side use wire brush to get the paint off so it is bare metal a weak ground can mess the amp up and make it not work at all hope this helps you have a wonderful day
Aug 23, 2011 | Kenwood KAC-7204 Car Audio Amplifier
My kenwood kac-5204 amp lights up red but no sound???
when the amp lights up red that means proteion , an no sound mean input is gone on the amp . you have to take it apart an fix it
Jul 19, 2011 | Kenwood Car Audio & Video
My kenwood light is red it turn green 4 a slpit second n turn bac red n want play my subs need help how to fix it
UNHOOK YOUR SPEAKER WIRES FROM AMP/IF THE GREEN LIGHT STAYS ON IT IS ONE OF
YOUR SPEAKERS.
Dec 21, 2010 | Kenwood Car Audio & Video
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Light stays red
I do belive this amplifer has a red light when it is on... I know my Kenwood does. I suggest checking all your wireing between your amp and your speakers, check the impediance between your positive and negative terminals on your leads to the subs.
Mar 28, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood KAC-8103D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
