Question about Frigidaire PLHS67EES Stainless Steel Side by Side Refrigerator
COMPRESSOR SOLENOID CLICKS EVERY 5-10 MINUTES AND ICE MAKER MAKES ICE BUT IT DEFROSTS AND STICKS TOGETHER. I DON'T USE MUCH ICE SO MAYBE THAT IS THE PROBLEM.
    Director Badge:
    Uploaded 100 video answers.
  • Frigidaire Master
  • 489 Answers
This compressor was clicking off at PTC. I installed 3n1 hard start kit. compressor did not start - means need new compressor.
Posted on Nov 26, 2015
  • 72 Answers
The compressor clicking that often is a sign of a weak PTC relay or a bad compressor. You can install a 3n1 Hard start kit available at most HVAC stores for $20, it is very simple to install, if the compressor continues to click, then it needs to be replaced. This maybe the reason that the ice cubes are getting stuck together but evaporation of ice does occur if they are not used regularly, hard to know which it is without seeing the ice cubes
Posted on Jun 15, 2009
Avanti 1008W
To manually defrost just unplug unit from power outlet for 12 hours,it will automatically defrost.But if these problem is occurring again n again then issue is with defrost assembly parts,the defrost timer,the thermostat and temp sensor in freezer section causing the problem.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Water leaking from bottom of freezer
Its defrost issue.The refrigerator is not defrosting on time,its defrost cycle is running late causing these problem.
Can be faulty defrost system parts or issue with defrost timer.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | General Electric GSH22JFX Side by Side...
Leaking water on the floor
The timer is faulty near compressor and due to these defrost cycle is taking place early or the defrost is not working at all.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
The ice in my ice maker bucket is melting and refreezing into a solid mass. I just looked at a recently made cube and it still has liquid in the center.
Yours has a 215846602 Defrost Timer, Located inside the fresh food compartment. I believe that it's sticking in defrost and you possibly need a new defrost timer.
Here is a photo location of the timer # 23 is the timer. I want you to turn the timer until the refrigerator compressor stops. Time it for about 25 minutes and the refrigerator should restart. If not then it's sticking in defrost so again turn clockwise slowly until the compressor restarts. That is possibly what is causing the melting and refreezing. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 19, 2009 | Frigidaire FRT18S6AQ Top Freezer...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Jul 13, 2008 | Refrigerators
Frigidaire PLHS67EES Stainless Steel Side by Side Refrigerator Logo
155 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
