Inches to decimals table
1 5/8 + 2 3/4 into decimals
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
4.375
Posted on Apr 15, 2014
What is the decimal equivalent of 1/4 inch
Hi John:
1 divided by 4 is
1 decimal 00 (1.00) divided by 4
100 divided by 4 is 25
1.00 divided by 4 is .25 (Decimal 25)
Hope this helps.
Oct 14, 2015 | Office Equipment & Supplies
2 inches = 5.08 centimeters
I suppose the best way to get an accurate conversion is to run it through Google.
Just type:
2 inches in cm
and it will give you the conversion.
Aug 24, 2014 | Building Materials
.317 inches is .317 inches.
If you want a conversion to some other unit, which unit?
May 27, 2014 | Office Equipment & Supplies
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
http://bit.ly/1bUVmuW
Nov 25, 2013 | Computers & Internet
I need to know how to get to Table Set on the TI-85 because I need to find the x intercepts on the graph, but I can't find it. How do I get to it?
try this one:
(first). Set up a function in the TI85. how?
Step 1. Press the [Y=] key to open the function editor.
Step 2. Type in the function you want in the Y1= line.
Step 3. Press [2nd] [QUIT].
(second). Create a table of numbers using the Y1 function.
Step 1. Press [2nd] [TBLSET] to open the table setup menu. On the line "Indpnt", highlight "Ask" and press enter. On the line "Depend", highlight "Auto" and press enter.
Step 2. Now press [2nd] [TABLE] , type in a value for "X", and press [ENTER].
Step 3. Continue typing more values for X to fill up the table.
(third). How can I see more decimal places for the numbers in a table?
Answer:
Step 1. Use the arrow keys to move the highlight over the number you are interested in seeing to more decimal places.
Step 2. Read the number at the bottom of the screen. You should be able to see anywhere from 9 to 14 significant figures for your number.
(fourth). Delete the numbers in a table by:
(The following procedure will work when the table setup has been set to ask for the values of the independent variable.)
Step 1. In the table screen, check the bottom of the screen to make sure that the cursor is not blinking at the bottom of the screen. If the cursor is blinking, press the [ENTER] key to stop the cursor from blinking.
Step 2. Use the arrow keys to move the highlight to the first number in the first column of the table (the "X" column).
Step 3. Press and hold the [DEL] key to delete the numbers in the first column of the table. The entire table should become clear with this procedure.
Thanks! I wish it can help you..
Feb 16, 2011 | Texas Instruments TI-85 Calculator
What is a desimal?
Check this website for answers
http://www.ask.com/web?q=desimal&o=15554&l=dis&qsrc=2871
Jun 02, 2010 | Goodman GMS90703BXA Heater
The question is: Convert 0.280 to the nearest 1/32
Divide 1.0 by 32. This tells you each 32th = 0.03125. Now divide 0.280 by 0.03125 and you get 8.96. So 0.280 equals almost 9/32ths. You can then check your math with an online "conversion table". Hope that helps.
Feb 05, 2010 | 2008 Ford Escape
I have a lot of numbers on the starting and ending points
Regardless of the way it looks, this huge number is just 1, written in scientific notation, with 9 decimal digits. This is due to the configuration of your calculator.
To revert to the default display mode, press [SHIFT][MODE][6:Fix] and select a number of decimal digits between 0 and 9.
If you do not like the [MathIO] (fractions, radicals) you can use the [SHIFT][MODE][2:LineIO]
Hope it helps.
Jun 03, 2009 | Casio fx-300ES Calculator
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
141 people viewed this question
k24674
