Question about Peripheral Enhancements DiskGO! Hard Drive
My external diskgo edge 160gb hard drive is not recognized by xp pro.(with SP3). makes beep noise like a just plugged a plug and play device but no drive on the computer . when i first got it I did put data on it but all of a sudden itjust stoped working the next day ???? any solutions???
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Hard drive crashed. New hard drive does not recognize Diskgo Edge, Suso I can restore
Hello Sharleen,
Your question is not understandable, If your hard disk has crashed, only professional data recovery services may help you out.
Make sure you go to DiskGO and get the new update for your drive, I some cases your hard drive needs updates to be recognized by your system
Sep 29, 2015 | Hard Computers & Internet
My External hard drive is not being recognized by the computer
Try hooking it up to another computer. What happens? This will narrow down whether the problem is with the drive or the computer ;)
Feb 20, 2011 | EDGE Tech Corp 160GB Diskgo Portable...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Edge DiskGo HD-D2-U2 External Hardrive not recognized by Vista
Hi
I having samsung E-250. I want to load dictionary in my mobile .How can I do that
Apr 08, 2009 | Peripheral Enhancements DiskGO! Hard Drive
Computer does not recognize external drive. Drive beeps.
i am unsure about this but try going to start control panel administrative tools services plug and play and see if it is enabled and has auto start-up type and that should enable your computer to to recognize new devices
hope this helps i really do
Mar 25, 2009 | Computers & Internet
My maxtor 200GB drive is not recognized by my CPU anymore!
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Oct 13, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Peripheral Enhancements DiskGO! Hard Drive Logo
1,588 people viewed this question
Top Peripheral Enhancements Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Peripheral Enhancements Computer and Internet Expert? Answer questions, earn points and help others
