Remote for GE6888 T-V
Won't switch on or off
What is the remote code for dick smith ge6888 tv.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Aug 21, 2017 | Televison & Video
Hi, looking for code for dose ge6810 on universal remote
http://www.ebay.com.au/itm/Replacement-DSE-Dick-Smith-Remote-Control-For-GE6806-GE6810-GE6888-LCD-TV-/371284708271
Apr 23, 2017 | Universal Televison & Video
Remote starter won't start engine, now check engine light is on
Need more information. Does the car start normally with a key? Is there a switch for a mechanic to disable the remote start while working on it (some units have a toggle switch)
Apr 06, 2013 | 2008 Chevrolet Silverado 1500 2WD
Tv won't switch to game mode without remote
You can buy a universal controller on Amazon or check ebay for an old remote for your TV
Mar 23, 2013 | Televison & Video
Ceiling fan won't turn on with remote or wall switch
it is a new fan? If so electrician needed..
If not try replacing batteries in remote.... its happened to me...
Oct 31, 2012 | Craftmade International Dryers
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't...
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
May 23, 2011 | Prestige Remote Start
Car 97 camry wont start but lock and unlock work
Won't start with the key? The issue is with the car. Won't REMOTE start, the issue may be with the hood pin switch (located under the hood) or, if it's an older system, the issue may be with a toggle switch under the dash.
Apr 25, 2011 | Prestige Remote Start
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
