Question about HP ENVY m4-1115dx 14" Notebook PC - Refurbished
Laptop fan is lod and error code on startup then quiets down
I get a 90b error code on startup. fan is loud but quickly quiets down. would that be a problem with the fan itself or another hardware issue?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
How To Fix The HP Notebook System Fan 90b Error Message On Startup?
The HP Notebook System Fan 90b Error Message On Startup indicates a serious problem which exists in relation to the heat removal process. Here, as per as HP technical support study is concerned, one of the two possible events is possible: first, the system fan is not at all spinning or even it may be the case that the system fan is not spinning properly and the second cause may be the temperature inside the case which is too high and the fan can't spin fast enough to remove the heat situation.
Steps to fix the HP Notebook fan error 90b
Step1: Working with the exterior vent
·If a user is noticing that the system fan is spinning and is blowing quite warm air from the computer, then cleaning all the exterior vents to remove dust buildup instantly by blowing air through the vent openings is necessary. This should be done while the computer is completely in "off' mode. Dust can further accumulate inside the vent opening and all around internal cooling components to prevent the heat removal process.
Step2: Perform a instant hard reset
·Performing a hard reset can further reset all the recorded thermal values in the memory by enabling you to work with the computer again even if it's only spinning for a short time to access. Save all the important files before it is in service process.
Step3: Updating the BIOS
·While updating the BIOS set-up, it may further help prevent this critical error from occurring in future as suggested by HP Notebook support
Step4: Computer servicing process
    ·Enable the computer service to easily clean up all the internal components and then replace the system fan carefully if necessary. Ensure that all the following items are well addressed while servicing
    ·Thoroughly remove all the available dust from all internal cooling components in the device.
    ·Ensure that wires from the system as well as from the CPU fans are well connected to the motherboard in secured mode.
    ·Ensure that your system fan blades are spinning correctly, and are not producing any unwanted noises. Replacing of the system fan is essential if it's not working correctly. Your above issue is now resolved completely. But do call us if you still have problem with your HP Notebooks at HP notebook Customer Support Toll-Free 1-800-213-8289 section anytime.
Posted on May 02, 2017
90B fan error
Start your notebook and start tapping the F2 key. In the diagnostic screen perform the hard disk diagnostic. If the diagnostic reports a hard disk smart test fail, then your hard disk is failing and must be replaced. That is the only way you will be able to return your notebook to useable condition.
If hard disk is ok I suggest you goto HP support Forums at
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs
Jan 23, 2014 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Compaq CQ56-219WM says system fan 90B is not operating correctly
this is what i did. Open my laptop, get out the motherboard and disconect the fan, change the termal sink, clean all inside, reconnect all and ready, then when you got it, change the cpu fan, i got it, it cost to me only 16.50 dlls. My laptop is now running properly.
Dec 27, 2012 | Compaq Computers & Internet
System fan 90b not working
Check for dust build up. If non then the fan needs to be replaced.
Apr 03, 2012 | HP Computers & Internet
I get this message when I turn on my laptop. It's almost a year old. "The system has detected that a cooling fan is not operating correctly. Continued operation is not recommended and may...
More that likely the fan is going out. Check the fan exhaust to see how much air it is moving if any. A laptop cooling pad will probably help out and possible prolong failure. If its under a year old, the maufacturer may fix it for you. You'll just have to contact HP and see if they will, or if they can get you a new fan to replace yourself if they wont do it for you.
Sep 11, 2011 | Computers & Internet
I just got my Vaio PCG-K33 operational once again by installing a replacement LCD screen. Now I realize why I was not in a rush to return this laptop to running condition. The cooling fan runs constantly...
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
VAIO Battery Replacement program
Hope this will help you. All the best.
Sep 17, 2010 | Sony VAIO PCG-K33 Notebook
Computer will not come on loud sound from pavillion repeats it self. The fans will spin and the blue light on pavillion comes on. moniter screen will not come on the power light is on
On some computers, when you turn it on, the fan starts to run at 100% of its speed, i.e., very noisily.
Then, when it is detected that the computer is functioning, and _not_ over-heating, the fan will slow down, and quiet down.
So, what is the nature of the "loud sound" ?
Continuous? Beeps, in some pattern?
Take the computer to a qualified technician, for better trouble-shooting.
Jun 09, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
How do I cool my cpu? I just replaced the fan in my dell lattitude d510 laptop because the old one was very loud. My new fan is quiet but i've noticed that my when doing cpu intensive things my cpu...
Ok get and install a program called speedfan it will allow complete control over the fan & you should be able to set it to work
www.almico.com/sfdownload.php
Feb 17, 2010 | Dell Latitude D510 Notebook
Kenmore Coldspot freezer is buzzing loudly
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure.
Eric
Jul 03, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fan Error
You may have a faulty fan, check to fan, it should spin freely, if not the fan needs to be replaced. The fan and heatsink assenble may also be clogged with dust, remove the dust and vacuum to clean.
Jun 07, 2009 | IBM ThinkPad R51 Notebook
Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Sep 16, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
HP ENVY m4-1115dx 14" Notebook PC - Refurbished Logo
60 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
