Question about Cobra 18 Ultra Weather Band Cb Radio 40 Channel 3 Weather Cb W1 W2 W3
Pa problems hooking up a pa speaker need help
    Genius:
  • Cobra Master
  • 1,795 Answers
Look on the back of the radio. See those two holes that you can plug a speaker into, well one is for CB the other if for PA. plug your Pa speaker into the appropriate connector and you have Pa capeablity. You must turn the switch to pa on front of radio.
Posted on Nov 25, 2014
How do I hook up my realistic mpa 25 20watt pa amplifier
hook up speaker common wire to com,then hook up the speaker wire to whatever ohm the pa speaker is,regular ones are 8 ohm,stay away from 70 v,plug in a record player or aux in the rca jacks you can use 12 volts or 120 volts
Jul 21, 2015 | Audio Players & Recorders
Why does the Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
nothing,thats what its supposed to do. Don't try transmitting on pa though you will blow that speaker. the type you would need is a bull horn speaker.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
Why doesn't my radio operate in the "PA" mode?
Some radio's do this (specifically Uniden) for some unknown reason. Ideally you plug a speaker into the PA output and when you switch to PA mode, the CB transceiver part should turn off and only your voice should come out of the PA EXT speaker to make it act like a personal megaphone.
How to hook up a pa speaker to a uniden vhf
Hi
From the owner's manual (link below) Page 5.
To wire the PA speaker, use the orange (+) and black (-) wires.
-Steve
http://www.uniden.com/pdf/SOLARA%20DSC-BKom.pdf
Mar 21, 2013 | Uniden Solara Vhf Dsc Fixed Mount Radio
How to hook up a pa speaker to a vhf radio
Hi
To wire your PA speaker, use the orange (+) and black (-) wires. This is from the owners manual, page 5 from the link below.
-Steve
Mar 20, 2013 | Uniden Solara DSC VHF Marine Radio
Peavey sp2 pa speakers quit working
Ok,
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
Wiring a pa
right next to the external out put of the external speaker is a similer plug .It says PA. set the plug in the outlet and push on it to make sure it goes in and now you have PA.
Aug 03, 2012 | Cobra 19 Ultra II CB Radio
How do you hook up a pa to afree spirit model number tr127fs cb radio
You can get a pa speaker at Radio Shack.....in the back of the radio there should be a pa jack, just plug it right in and put your radio on pa function, and you should be ready to go.....hope this helps....
Mar 07, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
PA squalls when mike pushed
Try running a temporary wire for grounding.
Tom
Jun 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 18 Ultra Weather Band Cb Radio 40 Channel 3 Weather Cb W1 W2 W3 Logo
98 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
