Question about Humminbird 1197c GPS Receiver
My Hummimbird 1197-c is not displaying the waypoint markers, or the tracks when I turn it on from the day before? It is not full either. I also seemed to have lost my old waypoints I had on there?
Lost waypoint and track data?
2 Suggested Answers
  • 661 Answers
SOURCE: trying to transfer waypoints off lowrance unit got
Hi danshell,
Please follow the below instructions carefully :-
I assume that you have the software installed and your memory card reader or the SD card reader is working properly , and you are able see the removable drive which is relevant to your memory card.
Firstly after you insert the memory card in your device , turn on the GPS system , and then you need to press the menu button two times.
When you do that you need to highlight the setup option , and after that you need to select transfer my data and then press ok or enter.
Now it will ask you to either save or load , here you need to select save.
Then you will find a menu displaying the memory card and the default filename which is data.usr.
when you highlight the save data option and select ok or enter you should get a message as 'User Date Saved Successfully'.
This message confirms, transfer of data to SD card successfully.
Now when you save it successfully , then only you would be able to open up the file from the memory card via the software application that you have.
In case you have any queries , feel free to get back to me.
Posted on Jul 01, 2011
How do i erase tracks on 525S
To edit an existing waypoint:Or MOB
1. From the Home screen, select Information > User Data > Waypoints.
2. Select the waypoint you want to edit.
3. Select Edit Waypoint.
4. Select the waypoint attribute you want to change (Name, Symbol, Depth, Water Temp,
Comment, or Position).
To delete a waypoint or an MOB:
1. From the Navigation chart, use the map pointer ( ) to highlight the waypoint or the MOB
on the Navigation chart.
OR
2. Select the waypoint or the MOB you want to delete.
3. Select Review > Delete (The Review button is only shown when more than one waypoint
is in the vicinity.)
Sep 24, 2009 | Garmin Gpsmap 525s Dual Frequency Combo...
Memory full, cant delete stored favourite destinations, sat nav turns off when delete is pressed.
Hello vinny!!
Perform a hard reset to clear all your memory!!!
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
Jul 12, 2008 | Garmin GPS
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
When using tracks how do you watch the trail you are leaving
On the Map Setup page under Track change the option for Track Log from Off to any other desired zoom level. Moreover, go to Tracks page and choose Setup. Tick 'Wrap When Full' and choose a Color that would be more visible/desirable Color for your track.
Feb 08, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Inaccurate Garmin GPS
Have you enabled the 'WAAS' option?
This improves accuracy greatly
Jan 19, 2009 | Garmin GPSMAP 295 GPS Receiver
I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
Jan 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
My Garmin Foretrex has a serial port. What software is available to download tracks and history to a PC
You can download tracks and waypoints via EasyGPS for free, or ExpertGPS or Garmin Mapsource. These programmes will transfer waypoints, tracks and routes to your PC.
If this solves your situation, please come back and rate our solution. Thankyou.
Jan 08, 2009 | Garmin eTrex Legend Cx GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Humminbird 1197c GPS Receiver Logo
13 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
