Question about Car Audio & Video
My Nüvi 700 series give yhe beep noises and the volume is up to 90%, but still I don´t get voice instructions as I used to a few days ago.
  • janos_szego Jun 16, 2009
    Very helpful and very expensive...
  1. Turn the device on
  2. Touch Tools
  3. Touch Settings
  4. Touch Language
  5. Touch the blue box under Voice
If that doesn't bring the voice back, you'll need to redownload them. You can do that here.
Posted on Jun 15, 2009
My garmin 200 gps is not coming on?
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Screen does nothing just says garmin
Resetting Your nüvi
Aug 24, 2011 | Garmin nuvi 205W GPS Receiver
Garmin turns off when Garmin screen comes on
Resetting Your nüvi
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
I'm not getting verbal directions from my Garmin nuvi 260W. How can I fix this problem. A day ago it was working properly.
If you are not receiving any sound on your N?vi 2xx thefirst thing to check is that the sound is not muted. To ensure that your unitssound is not muted please perform the following: Turn the device on Press the Volume button on the 'Where To?', 'View Map'screen Ensure the Mute box is not 'checked' If the mute button is not 'ticked', you will need to changethe voice to ensure that the preset voice is not faulty: Turn the device on Touch the Tool icon Touch Settings Touch Language Touch the language voice next to Voice Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you arerunning the latest software which can be done by installing a program calledWebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the softwaresuccessfully installs.
Jan 21, 2011 | Garmin nuvi 260W GPS Receiver
I am having problem with the sound. All of a sudden there is no voice. I tried to up the volume but the black lines turn to yellow and still no sound. What can I do?
You didn't give a model so you'll need to select it from the selection below.
I presume you checked that the mute box is not ticked beside the volume settings.
The most likely cause is that the voice file is either corrupted or has become unselected. To solve this problem;
To select or change the voice language on a nuvi 200/205/500/700/705/800/805/1200/1300/1400/1600/5000 series or zumo 600 series device:
  1. Touch the Tool icon
  2. Touch Settings
  3. Touch Language
  4. Touch Voice
  5. Touch the Voice Language you would like to use
  6. Touch 'Ok'
  7. Touch and hold the Back button to return to the main "Where To" and "View Map" menu
At this time your device should speak in the language you have set in step 5.
To select or change the voice language on a nuvi 300/600 or zumo 400/500 series device:
  2. Touch Locale
  3. Touch Voice
  4. Touch the Voice Language you would like to use
  5. Touch 'Ok'
  6. Touch and hold the Back button to return to the main "Where To" and "View Map" menu
If the voice file is corrupted you'll need to download it from www.garmin.com First connect your satnav to your computer, download the latest version of webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it on your computer. When it's installed it will search for updates for your satnav. After software has been updated it will give you a list of voices you can download. Select the ones you want by clicking on them. Click next and they will be downloaded to your satnav. When they're downloaded you'll need to repeat the instructions in para 1 above to select one on your satnav.
Aug 05, 2010 | Garmin GPS
HI. Where can I find the model for my GPS? I says Garmin Nüvi on the front, on the bottom it says FCC ID: IPH-01278 IC: 1792A-01278 MT102 10R-023994 Thanks, Nina
If its the 600 or 700 series its located on side on Serial Number where you hook it to Suction Cup Mount
Love my Nuvi760
May 29, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
No more voice commands
Is it still under warranty
if so take it back to the store
Feb 05, 2009 | Garmin nuvi 200W GPS Receiver
Olympus DW90 Digital Voice Recorder - Display Shows CHK and beeps
Make sure the recorder is out of the HOLD position. The HOLD switch is like the on/off button to the device. If you move it out of HOLD the device should come on and you should be able to start recording on it.
Jan 22, 2009 | Olympus DW-90 Digital Voice Recorder
Where can i get an online Manual for a Voice Star VS700 Bluetooth
Hold the power button down, once it beeps, keep holding down the power button but push in the volume up button, once it beeps let go of the volume up button and while still holding the power button push in the volume down button. the pass code is "0000".
Dec 11, 2008 | Radio Communications
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
