Question about Continental Manufacturing Company Value Line CPT92 Stainless Steel Commercial Refrigerator
What setting should my ranco pressure switch be set at for my continental cpt92 refrigerator
Top of the fridge is not staying cold. not sure if my settings are right.
Ranco k series
You need to take that control to a refrigeration supply house and get the proper control replacement. Those are factory set. One is differential and the other is set for temp. The adjustments in the field just don't stay put and will fail after messing with them. Ranco has a book that the supply house has that will give you what you need and the part is generally on the shelf. Hope this helps and good luck.
May 16, 2014 | True Refrigerators
If it's for "refrigerator" temps 37 to 40 . 37 lb cut in with a 12 degree differential. On a R12 system. Is this what you have ?
Mar 24, 2014 | Continental Manufacturing Company Value...
My fridge will not turn off. I have to manualy turn the thermostat to '0' then turn it back to 2 or 3. It is freezing all of my food. Help please!!
Make sure both the thermostats stay on Marked recommended setting, should be somewhere in the middle. check your freezer setting in the back of freezer wall, it should be open to allow the cold air in to the freezer and not forced down to the refrigerator. Make sure your freezer vent is not blocked by a bag of frozen vegetables or something similar. This will have the same effect as the vent being closed forcing the cold air down to the refrigerator.
May 20, 2011 | Kenmore Top Freezer Refrigerator
The fridge is not getting cold
Just check and fix below : - Refrigerant pressure ( need to top up if found low pressure) - Wrong set of thermostat ( set it to middle or a bit colder)
Regards
Dec 19, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
The refrigerator is not running cold.
most fridges are operating best at +(plus) ,-(minus)3.5 degrees C, at what setting do you have it currently? (settinngs can be between 1(one) up to 10(ten) depends on model and make). most people realize that the fridge is not cold and set the settings(fridge control) up, that is wrong, try to keep freezer build-up clean and run the fridge on a setting of 1(one). switch of the mains, clean the fridge and follow above instructions. if the problem still exists after that then you need to replace the gas
Dec 12, 2010 | Maytag MTB1954ME Top Freezer Refrigerator
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Continental Manufacturing Company Value Line CPT92 Stainless Steel Commercial Refrigerator Logo
18 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
