Question about Samsung LN-S4041D 40 in. LCD HDTV
My Samsung LNS4041DX has a hard time trying to turn on. The red led light blinks a couple times and around 2 or 3 minutes later, it finally comes on?
    Problem Solver:
  • 7 Answers
Replace the 4 Capacitors on the power supply board that are buldged up they are on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worke perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
  • 3 Answers
My SAMSUNG LN-S4041DX/XAA .ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} TV just clicks on/off repeatedly but it won't power up. The LED flashes 4 times and then it goes off. TV is 3 1/2 years old and of course out of warranty.
I am not ready to call a service person because they never seem to do anything but replace boards which is what I am doing.
Here is what I have done so far:
1. Replaced 10V capacitors on power supply board with higher voltage ones but same 1000uF rating. Didn't fix the problem.
2. Replaced entire power supply board with another one. Didn't work.
3. Now I plan to replace the main board on the right and the T con board at the top. I will do this separately to see if it fixes the problem. I will return whatever board that I don't need.
Can anyone think of something I am missing? Is it an easy fix that a repairman could do if he's good? I'm ready to call SEARS after this.
Thanks,
Anthony
Posted on May 24, 2010
  • wingsfan92 Dec 30, 2010
    Had the same thing happen after thunderstorms. Power must of surged and blown capacitor. Paid $ 50 for the repair guy to put in one that will never blow. (Used a higher voltage)
    Look in your area for electronics repair
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
Sony KDF-55E2000 power led blinks red 3 times....
Are you using an extension cable? If you are, try plugging it directly into the wall.
Alternatively, call up the helpline and they may be able to provide more insight into your specific problem.
Jul 20, 2017 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a Panasonic PT50LC13 Television. For about the last month when you tried to turn it on, it would come on then quickly turn back off and you could hear the fan running then the red light would blink....
For that model, there is a ballast kit that would need to be installed. A diode and 2 caps need to be replace on the ballast. Check the lamp as well.
Dec 16, 2009 | Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Jul 01, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung lns4041dx/xaa tv takes a long time to turn on the red LED light blinks 3 times then disappears - then LED light comes on again repeats the process for about 7 - 10 minutes then the TV turns on. ...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 31, 2017 | Televison & Video
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung LN-S4041D 40 in. LCD HDTV Logo
713 people viewed this question
Jerry Greenberg
Jerry Greenberg
