Question about Toshiba Satellite M115-S1061 Notebook
Computer will not turn on, even while plugged in and with battery
My mechanic went to turn on his laptop and it would not power on.
While plugged into adapter, power and battery/charge lights are not on as if power is not being supplied (DUH!) ;-)
This machine has had the screen replaced (by the end user and it was working fine after installation, reboot, and was utilized daily for personal/business use.
One day my mechanic, Johnathon tried to start it and it hasn't worked since.
I have computer refurbishing skills and intend to solve this issue and before I unbutton the unit I'd like to know if there is a fuse or Master Reset switch or a jumper I can pull to fix the problem.
Any help or a schematic of this motherboard would be greatly appreciated.
System Unit; Toshiba Satellite M115-S1061
Model No; PSMB6U-00G005
  • Toshiba Master
  • 5,660 Answers
There is no Master Reset Switch, Circuit Breaker, or Fuse. (I'm just full of cheer, huh?)
A.Sounds like it's a problem with the DC Power Jack. The port where you plug the AC adapter into. This jack's body is made of plastic, with a metal round pin in the center, and either a round metal shell, or a flat contact lug/s in the back.
The thick round pin in the center is the Positive (+) connection. The thin metal shell, (Or the flat contact lug/s), is the Negative connection.
This is what the jack looks like not installed,
http://powerjack.us/index.php?main_page=product_info&products_id=9822
Hard to see from the small photo, (And trying to enlarge it does no good), but there are metal flat prongs that are attached to the body of the jack. They, of course, go to the Positive and Negative connections of the jack.
These are soldered to the motherboard.
1.Accidentally, the AC adapter while plugged in, can be bumped, and the ensuing force can damage the body of the jack. (Replace the jack)
2.The force can also break loose some of those solder joints. It can crack them.
(Re-solder the solder joint/s)
B.The motherboard area for this jack, has a circuit that senses whether power is to come directly from the AC adapter, or the battery, and also senses when the battery is low, and needs a charge.
This circuit could be damaged. No offense to you, or your computer tech skills, but you won't be replacing this circuit. You will be replacing the entire motherboard. (Check on Ebay, is a tip)
Here is information about how to completely disassemble a Toshiba Satellite M105. You'll find this model is close to the M115, and the info will cross directly over.
There are photos that help detail the information, as you go along. You can click on each photo to enlarge. You will see -> Page 1::Page 2::Page 3, at the top and bottom of the article. You are on Page 1.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
Tips from me
1.MAKE sure you buy an ESD wrist strap, and use it. Radio Shack has them for around $6.
Clip the alligator clip to the metal frame of an empty computer case, or a computer that is open, and unplugged from power.
2.If this is your first time, I suggest digital photos, write down notes, and make drawings, as you disassemble. You may get called away in the middle, and this info will be there for you when you get back.
3.Use a clean egg carton for the various screws. Label each egg holder for where the screw came from. Makes life a lot easier!
Posted on Jun 15, 2009
No power. I went to the computer store and they used their own plug to override the battery. They also tried main battery replacement. Both items did not work to power up my computer. Before it went...
Step 1:
With unit off, and unplugged, remove battery from bay.
Step 2:
Plug unit into AC adapter and turn on.
Step 3:
If unit turns on and working well...need to replace battery with new one.
Step 4:
If unit turns on, but still giving you issues -- take in for repairs.
Jan 15, 2013 | Acer Aspire 5253
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
I removed my ac cord and the computer went dead (typically it runs on battery when the cord is removed). Now, after plugging back in and powering back up, I've got that 3 flashing red, then 1 green on the...
Remove battery and see if it turn on, to do this turn your laptop upside down and you will see the batterry.
Dec 03, 2009 | Dell Latitude D600 Notebook
Battery not charging . light comes on power supply but batterlife went down even thogh it was plugged in. now now enough power even to start up
Try turning off your computer, removing the battery for 10-20 minutes, put it back in, and turn it on/charge it. If this doesnt work it sounds like a short in either your charging cord or your battery.
If its still under a warranty then send it to your dealer.
Aug 28, 2009 | Computers & Internet
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
Laptop Blackout..
Your Battery went bad so you need to replace it.
and if you wanna run through AC power adapter then just take off your battery then plug in your power adapter then turn it on it should be working.
Feb 04, 2009 | AMD IC Power CN5560 Notebook
Won't turn on
how old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Jan 16, 2009 | Computers & Internet
Attempting to load but suddenly shut off..
It sounds like the laptop was in a screen off state (happens when it is left on but not used for a while).  When you pushed the power button it went to shutdown, and notified you that someone (you) is still logged on.  Any unsaved work could be lost, hence the warning.
Five minutes later when you went to switch it back on, the laptop coincidently must be low on battery, to the point where it will not stay on, and exhibits the problem you are experiencing now.  Try plugging in to power and make sure that the battery is charging, and try again.
Nov 06, 2008 | EliteGroup ECS A535 Notebook
Computer doesn't start.
I would try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372748&lc=en&cc=us&dlc=en&product=500508&rule=45203&lang=en
You also might want to go into your local Staples to find a 3rd party power adapter to see if your power adapter is bad (Staples has no return policy, thus you can try it out and return if needed).
Nov 11, 2007 | HP Compaq Presario V2000 Notebook
Toshiba Satellite M115-S1061 Notebook Logo
671 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
