Question about Garden
No water underpressure coming out
Have a northstar pressurewasher and the motor runs but nothing comes out.don`t have the owners manual to trouble shoot it.it worked fine two months ago.took hose off at the pump and still there is no pressure water comming out of the pump.
phil
  • 92 Answers
SOURCE: pressure washer won`t pressure up
Dear rustrick281,
It seems that your pump needs a good service. The sucktion and delivery valves got faulty. The high pressure seals and the low pressure seals must be renewed. The pistons must be checked for corrosion and cracks. Also the pistons or one of the pistons got stuck due to oncorrect lubrication. The swash plate that drives the pistons could have got loose. So the motor turns and the pump stays dead. So a good examination and service must be done to the pump. To renew all the parts I have mentioned, you must buy a PUMP KIT for you model. The pistons are not included in the pump kit....but hopefuly the pistons are still good. Also the oil inside the pump must be renewed.
Regards,
Fulltech.
Posted on May 07, 2009
  • 32 Answers
SOURCE: no water is coming out of the pressure washer
i think you have a blocked nozzle on the lance, get a paper clip and push it right down the end and wash out.
Posted on Jul 04, 2009
  • 156 Answers
SOURCE: Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Posted on Jul 06, 2009
SOURCE: Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Posted on Jul 22, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
97 deville northstar where are fuses and relays located
under steering wheel to left ,if it's the motor running hot don't wait get on it northstar motors are big problems when it comes to keeping motor cool head gaskets ,and ,the water pump is a piece no well made,it's driven off the cam on the drivers side of engine.
Mar 17, 2017 | Cadillac DeVille Cars & Trucks
My 98 Cad Deville will not start it says anti theft problem
changed moter in 1998cadillac deville northstar v8 wont run need to know how to reset computer for that moter
Jun 16, 2011 | 1998 Cadillac DeVille
I find the the oil keeps running low before the engine oil life will het 0% sometimes it's not at 30% and the oil is almost completely gone. Is there a know problem with the sts burning up oil or leaking...
the northstar engines burn incredible amounts of oil....your owners manual will explain.....'oil consumption'....but the reality is keep checking it...the 'idiot light comes on...or info center...low oil when it is 2 quarts down....another of GM follies...i have a northstar Caddy too.....
Mar 31, 2011 | 2006 Cadillac STS
How do I adjust the pressure on an old Northstar Pressure washer. Honda 18.0 HP, GX610 V-Twin
The following link will give you great troubleshooting for all pressurewashers. http://www.pressurewasherservice.ca/serv02.htm
There are several way to increase pressure. Primary way is to turn the pressure regulator knob in the direction to increase tension on the spring. Pressure regulator is located on the pump (or very neer) and usually has a large spring. Sometimes the spring is hidden under a twist knob. If the adjuster seems to be already turned to max then you may need to just change the pressure tip. The tip/nozzle is actually where the pressure is created by restricting the flow of water thru a very small opening. Use a new tip of the same gpm flow that is required by your machine. 18 hp machine has potential for very high pressure and high gallons per minute. Use trouble shooting guide above for more information. Good luck
Sep 30, 2010 | Northstar Garden
Builds up pressure won't spray
pressure relief valve is faulty. replace.
Aug 10, 2009 | Garden
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
