Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
Pride victory 10 scooter
Speed pot
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
What does the 7 beep code mean on my Victory Pride 10 mean when I turn the key on ?
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me
Regards
Rob
www.gewizrepairs.co.uk
Jul 11, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
I need to know how to replace the power pot on a pride victory 3 wheel electric scooter
hi, do you mean the throttle pot or the speed pot ? located on the tiller panel ..
Regards
Rob
May 02, 2014 | Pride Health & Beauty
My victory scooter will not go foward
if the throttle pot feels okay that is what the lever is attached to ? is it loose ? if it goes in reserve okay i would say it's the throttle pot, i can get you one of these if required.
Dec 06, 2012 | Pride Mobility Products Pride Mobility...
Pride Victory My scooter will not run wide open
I would say to change the pot,its the variable contacts on the high end of the speed pot that is worn out not making contact.
Jul 06, 2010 | Pride Mobility Products New Pride Mobility...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Oct 04, 2009 | Pride Mobility Victory 3 Wheel Electric...
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
