Question about Harbinger HA1000 Powered Mixer
Connecting How to connect to speaker and monitors
  • Harbinger Master
  • 3,382 Answers
Try this link: http://harbingerproaudio.com/wp-content/uploads/2014/03/Manuals/Harbinger_HA1000_Manual.pdf and read the manual, there are a lot of combinations and I am not in the mood to write a book tonight. I do not know what you have.
Posted on Oct 21, 2014
I want to know to to plug speakers into the monitor, i have them in and no sound
Do not plug speakers into monitor , its not intended for that !
A monitor is a very low out out put to use only for connecting an amplifier input !!!
Nov 29, 2015 | Computers & Internet
Speakers not working. do I need to update something or just buy some more speakers
First step to troubleshooting speakers is check that the audio cable is properly connected then check if the sound is muted or not then try connecting external speakers to determin if the monitors speakers are ba dor there is a problem with the pc.
regards
Mar 07, 2015 | Computers & Internet
How do i change speakers
There are couple of questions to ask , are u trying to connect the speakers to the monitor for a tv connection or using it to connect to a computer system , if connecting to the computer system , the audio settings have to be changed to the current speakers you connect to the monitor , or there might be a up link cable u might have got when u bought the monitor using which the sound will come out .
Dec 14, 2014 | LG FLATRON M237WD 23 inch LCD Monitor
What should the connection from my vx2250 viewsonic monitor to my desktop look like?
If your monitor has built-in speakers, you should have a connecting cable with stereo mini plugs on both ends installed between the line out connector (usually green) of your sound card and the audio input connector on the monitor. I have an HP monitor with built-in speakers and that's how it is connected
Nov 08, 2012 | Viewsonic Corporation Viewsonic...
Hyundai L90d+ has internal speakers. There is one cord connecting on the back to two positions next to each other. Using vga port for connection to computer. How to connect speakers to computer? I...
Plug the headphones/speakers into the computer. Go into Control Panel -> Sounds and Audio Devices -> Audio Tab -> Sound playback -> Select your headphones from the drop-down list. Voila headphones/speakers that work.
Sep 14, 2011 | Hyundai ImageQuest L90D 19" LCD Monitor
Monitor Speakers are working however I can not adjust the volume to a level I can hear (I am not deaf) I have gone to the control panel and increase the settings there but still unable to hear ir clearly....
The speakers for the monitor are low rated in terms of required power input. You can open the speaker box and disconnect one from the two wires connecting the speaker and leaving the other one still connected direct to speaker.
provide a resistor from a range of 25000 to 30000kilo ohms and connect the chosen resistor between the wire which was cut on the speaker. this way you will provide what we call attenuation on the path. please check and try this method. thanks for asking fixya.
thanks.
Jan 06, 2010 | ViewSonic VA1930WM LCD Monitor
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
I have a syncmater 2333 HD and after connecting to my pc, i seemed to have lost all sound. when connecting speakers and earphones, there is still no sound. thanks
Did you plug in the audio cable to the back of the computer? If so, this may have disabled the front audio connections (or vise-versa). Try unplugging the audio cable from the computer (that is connected to the monitor) and see if your headphones work. If so, there is the solution to that problem.
Check the audio connection on the back of the monitor and double check that it is plugged into the correct port on the back of the computer. If the monitor has amplified speakers, it would be a good idea to connect to the 'line-out' connector on your computer. This would avoid disabling your front audio panel.
Lastly, check the volume on your monitor's built in speakers. This monitor can double as an LCD television, so it most likely has a separate volume control (that defaults to 0).
Oct 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Connecting to the onboard speakers on the flatron 776fm monitor
You simply need a miniature stereo audio cable.  Radio Shack carries them.
srich
May 27, 2008 | LG Flatron 776FM 17" CRT Monitor
Connecting speakers to compacq computer
its a green round plug on the back of the pc
May 02, 2008 | Audio Players & Recorders
Harbinger HA1000 Powered Mixer Logo
85 people viewed this question
Top Harbinger Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harbinger Audio Player and Recorder Expert? Answer questions, earn points and help others
