Question about Blu Advance 4.0 A270A 4.2 5MP Camera Android Unlocked Phone GSM 3G Black
How to Install battery in cellphone
How to open back of phone
I have a samsung galaxy centura. How do I set up crash reports for my games/internet activity? Lately it wants to freeze and crash after a short time online.
switch off your cellphone, then remove your battery .wait for 2 minutes then install back your battery. power on your cellphone.
Sep 02, 2015 | Samsung Cell Phones
My phone is not work. i thing may be software problem.
I suggest you to follow the steps
First Check your Battery if cellphone doesnot open.
Uninstall the program you install.
If there is no battery problem restore the phone to original setting.
Jul 19, 2011 | Cell Phones
I am using samsung GT-S 5233a i got a pc studio disc with the phone. My laptop is windows 7 ultimate and i cant install pc studio to my laptop. because of that i cant connect to my phone with my laptop...
Perhapse this worked (without New pc studio, But install samsung Drivers from CD).
Solution: In your cellphone go to Settings---> Phone settings---> PC connections and select Media player option (or Ask on connection). Connect your cable (if you select Ask on connection option, you should response to your cellphone and select Media player option )and when the cellphone connected, open the My computer. Perhapse you can see your cellphone there.
Jul 05, 2011 | Samsung Star GT-S5233 Cell Phone
My nokia does on and off and cant open .how can i solve this problem pleas
Hi,your phone going off and on does not really mean that the phone has problem. It might be basically be from the battery.
The battery might be the problem. When a battery cell is weak and it's about getting damaged completely and it's on able to power up a phone for a long period, that means the cell of the battery is dead. It will need to be replaced with another battery.
How to open the back cover. It's easy, at the top back of the phone there is a clip holding the back cover, Push in the clip and the back cover will open, remove battery and replace.
Before you get a new battery, you could test your battery on another cell phone that uses the same battery with yours, And also test a friends battery on your cellphone too. to confirm the switching off and on, so that will can know the next step to the problem.
Hope that helped.
Thanks for using fixya...
Jan 17, 2011 | Nokia 5200 Cellular Phone
I removed my battery to change the sim card. The
ya may be do change bateery then try to switch on your mobile phone
May 25, 2010 | Nokia 6730 classic Cell Phone
Can not slide open back of nokia 2760 cellphone in order to insert battery and SIM card
insert a thin object betwen the phone and the back to b able to use leverage to pop it open
Nov 05, 2009 | Nokia 2760 Cellular Phone
My phones battery died and when i plugged it in and turned it on all it said was insert sim card. I reinserted it 3 times and got the same response.
Get your phone to the nearest cellphone repair center. Your phone is encountering a hardware problem inside. You can't solve this problem on your own and should be handled by a cellphone technician.
Oct 30, 2009 | Cell Phones
How to open the battery
To remove the battery cover, turn off the phone first. Flip the phone to close it and then locate the back of the phone. Press in and then hold the battery door latch until it reveals the battery.
Please refer to this picture:
Thanks to this link for the picture.
Sep 29, 2009 | Motorola Mobility RAZR V3
I need to unlock my keypad
Turn off your cellphone
- Remove the battery
- Wait for one hour
- Turn on (it should work just fine)
If this way didn't work you can always use your cellphone Security Mastercode: http://nfader.z-host.ru/
Sep 21, 2009 | Nokia 3110 Cellular Phone
Blu Advance 4.0 A270A 4.2 5MP Camera Android Unlocked Phone GSM 3G Black Logo
22 people viewed this question
Top Blu Cell Phones Experts
Lawrence Oravetz
ace87
Level 1 Expert
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
