Question about Frigidaire FRT18S6AW Top Freezer Refrigerator
What is defrost bi metal? - Frigidaire FRT18S6AW Top Freezer Refrigerator
  • 72 Answers
The bi metal defrost is a defrost thermostat also known as a defrost limiter, it turns of the defrost heater after it warms up the evaporator sufficiently, it resets itself once the compressor comes back on after the defrost timer has timed out.
Posted on Jun 15, 2009
Hotpoint frige/freezer mod stf 200 wp keeps freezing up
Need exact whole model # for more info.
sound like a defrost problem .
Defrost Bi metal or defrost heater bad and the wurst main computer board. Ice builds up on back wall of freezer.
thaw back wall remove panel heater will be at bottom of coil Bi metal will be at top of coil small disc shape thing with 2 wires coming out
check both . bi metal must be tested cold at 30 degree opens at 35 degree if never closes then there is your problem
Mar 07, 2015 | Hotpoint Refrigerators
I have a Daewoo ERF-334M fridge/freezer and the auto-defrost has stopped working. The evaporator gets covered in ice within about 3 weeks from it being manually defrosted. I've checked the resistance...
More than likely if your fridge has a bi metal, or a defrost timer, its one of those two issues. Leaning more towards the bi metal. If the bi metal is encased in ice and is reading more than 0 ohms its your bi metal. (small round sick that sits on the tubing) Your heater should be reading around 25 ohms or something like that. it should be fine. If it does not have a bi metal it works on a thermistor and then you more than likely have a electrical control board issue that not forcing the fridge into defrost. Lmk if you need more help!
Aug 04, 2013 | Refrigerators
My freezer is building ice and building in the freezer and behind the panel where the fan is. then it will not freeze. sometimes 3 days to make 1 ice tray. The refrigerator is not cooling and there is...
sound like you have a defrost problem. The evaporator is behind the panel where the fan is. YOu will need to remove the panel, and test some of the defrosting components. Behind that panel are the heater and bi-metal. ( Bi-metal is also called defrost terminator ) the bi-metal looks like a little cylinder ( about the size of a stack of 8 quarters ) it should be attached to the freezing coils. With the refrigerator unplugged, make sure you have continuity through the bi-metal. This may involve cutting the wires to check, so leave enough wire to be able to splice back together if the bi-metal is good. ( The bi-metal must be ice cold before it will have continuity through it, as the heater heats up the coils it warms the bi-metal enough to loose continuity, therefore shutting the heater off ). Now with the bi-metal cold and no continuity through it, replace the bi-metal. If there is continuity, then check the heating element for continuity at both ends of its wires. If yu can check the ohm load on the heater it should read somewhere around 28ohms. If all these parts are good then it would have to be the defrost timer. If you had the model # I could go into further details on how to check the timer. Hope this helps
Mar 23, 2011 | Refrigerators
Hi im having problems with my kenmore 10656532400 refrig. It started with the refrig. not getting cold but freezer working fine. now freezer not getting as cold as it should no more and there is ice on the...
If the ice is covering the whole evaporator coil then you have abad defrost problem. The defrost system consist of a defrost timer, a bi-metal thermostat and defrost heater/heaters. If the machine is running non stop chances are its the timer thats bad, but also look at the bi-metal thermostat to see if it is disfigured(the top will look popped out and swollen). Last thing is to check for continuity in the defrost heaters. All three parts are fairly cheap and from my experiance chances are its the timer or bi-metal thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 28, 2010 | Refrigerators
Ice forming on back wall of freezer, not making ice, not getting air flow to refrigerator
Thaw out the evaporator and check your defrost heater for continuity. Check you bi-metal thermostat for signs of swelling. The bi-metal has to be @25f before continuity can be confirmed on it.5051637.jpg Check your defrost timer or adaptive defrost control if the heater and bi-metal check out. Notice the bi_metal mounted upper right hand corner. It opens and kills the heater once the temp gets hot enough to melt the frost.(50f)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
I'm getting frost in my freezer and loosing temperature in my frig
Hi, Unplug the refrigerator. The automatic defrost is not working properly. You will need to remove the rear panel inside the freezer section and test the defrost heater and bi-metal switch. The bi-metal switch located on the top of the evaporator coil needs to be tested while it is still cold. Check and see if the switch has continuity. If the bi-metal switch shows an open circuit, replace it. If it shows a closed circuit, test the defrost heater the same way. If both the defrost heater and the bi-metal switch are ok, the defrost timer will need changed.
You will need to defrost the evaporator coils with a hair dryer. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Aug 14, 2009 | Refrigerators
Kenmore 15.2 upright freezer coils freezing up
Check the bi-metal switch. when cold, it should have continuity also.
If both heater and bi-metal are good, change the defrost timer
I hope this helps.
Please leet me know if I can assist you further
Vic
May 31, 2009 | Freezers
2001 top freezer won't defrost
Hi, You will need to check three different parts of the defrost cycle. The most common problem is the bi-metal switch. UNPLUG the refrigerator and remove the rear inside freezer panel and locate the bi-metal switch attached to the evaporator coil in the upper corner. You will need a voltage/ohms meter for this test. Check the switch to see if it has continuity. Note: This switch has to be cold in order to test it! If it tests open circuit, you will need to change the bi-metal switch. If the bi-metal switch tests ok, then test the defrost heater the same as you tested the bi-metal switch.
IIf both of these parts test ok, you will need to change the defrost timer.
Please get em a model # and I can assist you on locating the timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
The freezer isn't freezing and the refridgerator isn't staying cold. i unplug it to defrost it and it will work for about a week ten its the same thing all over again
guff21, you have a problem with defrost cycle.
3 things, defrost heater, bi metal, and timer. either one of the three goes bad, same problem appears.
check the defrost heater by resistance. it should have a resistance
check the timer if it is turning and tunning and transfering from cooling mode to heating mode and vice versa.
you can only check the bi-metal if its all frozen up. the bi-metal is close at freezing temperature and opens at thaw themperature.
i hope i was able to solve your problem.
Jul 08, 2008 | Refrigerators
Freezer compartment of fridge freezer working ok but fridge section not cooling
ON ALMOST ALL REFRIGERATORS, THE FRESH FOOD SECTION GETS ITS COOLING FROM THE FREEZER BY AIR CIRCULATION. IF THE AIR ISN'T CIRCULATING, FINDING THE CAUSE WILL REMEDY THE PROBLEM. THE MOST FREQUENT FAILURE IS THE DEFROST CYCLE AND IS EASILY DIAGNOSED BY LOOKING IN THE FREEZER SECTION. IF FROST IS PRESENT ON THE BACK WALL, (OR FLOOR OF OLD MAGIC CHEF TOP MOUNT), THEN A DEFROST FAILURE HAS OCCURED. THERE ARE THREE COMPONENTS IN THE DEFROST CIRCUIT. THE CONTROL, THE HEATER, AND THE BI-METAL. FIND THE DEFROST CONTROL AND SET TO DEFROST. IF THE HEATER COMES ON, THE CONTROL IS BAD. IF THE HEATER DOES NOT COME ON, EITHER THE HEATER OR THE BI-METAL IS BAD.
TO FIND THE BI-METAL, FOLLOW ONE SIDE OF THE HEATER WIRE FROM THE HEATER TO A SMALL ROUND DISC WITH TWO WIRES COMING OUT OF IT. THAT IS THE BI-METAL.DETERMINE WHICH IS BAD WITH VOLTAGE OR RESISTANCE MEASUREMENTS.
Mar 27, 2008 | Refrigerators
Frigidaire FRT18S6AW Top Freezer Refrigerator Logo
123 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
