Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice cubes are formed but they do not dispense. Seems like the arm is not spinning the coil.
  • GE Master
  • 4,655 Answers
It is possible that your ice maker has a problem with the thermostat located inside the ice maker itself is defective. The thermostat tells the defrost elements under the ice maker to come on for a few moments and the process of dropping the ice is begins and then completed. When bad it never begins the 6 steps needed to make Ice. Let me know if I can help you, Sea Breeze
Posted on Jun 15, 2009
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Dispser arm for cube or ice will not move to
the ice maker unit go bad fast :( the unit need to be replace unless its under waranty .
sorry but its happen all the time.
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have my indoor ice dispenser set for cube and it only dispenses crushed. How can I get it to reset back to cubed ice?
Easy fix.
Pull the ice bin out a couple inches.Look underneath the ice bin at the back wall of the freezer. You will see a hole in the back wall with a yoke device in it. The underside of the ice bin has a metal arm attached. The metal arm must go inside the yoke in the back wall.
Push the ice bin in until it seats in the locking tabs and the arm is inside the yoke.
Nov 20, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
THE ICE CUBE DISPENSER 0NLY SHOOTS CRUSHED ICE
yes and no ...... there is no real adjustment for it but you may have a sticking solenoid .....OK in the back of the unit remove the hopper and you will see the solenoid loop (white Plastic) in the back wall this need to pull up in order for the unit to dispense cubes. it maybe sticking ....now by moving it up and down a few times with your hand to make sure it is free....next dump all the ice out of the hopper and check the arm thathat sticks out the back of the hopper make sure it is not frozen after that reassby and place a few cubes back in the hopper to see if it is working..Let me know
Feb 16, 2008 | Kenmore 25.4 cu. ft. Side-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
88 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
