Question about Home Security
LockSAF won't close
Lid will not close
My smartdrive pride lid came off and I fixed it but now the machine won't work, any suggestions please?
Possible that the lid switch alignment is not proper and so does not activate when the lid is closed. Please reset this lid once again and check the switch continuity with a meter when the lid is shut
Jan 14, 2013 | Washing Machines
Lid won't close
Take the disc out, hold the disc holder down flat, then close the lid. Open up and will work as normal. If this works for you, please visit sun-light. co.uk
Dec 20, 2012 | Bosch Tassimo T20 Brewer Color Kit
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
Oct 13, 2012 | Maytag Washing Machines
Why won't my model 110 washer spin?
if it still has water in it check the lid switch,close the lid then open it a few inches and close it again,when you do this if you don't hear a clicking sound the lid switch is bad.watch this video and hope this helps
http://www.youtube.com/watch?v=MFsvLiuTniU
Sep 16, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
It seems that my 2005 Lexus ES330 trunk light won't turn off. How to check whether the trunk light is off when the trunk lid is close?
Remove the bulb if you think it runs the battery down. the switch is part of the latch assembly of the trunk.
Jul 07, 2012 | Cars & Trucks
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Apr 03, 2012 | Hotpoint VBXR1090D Top Load Washer
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Home Security Logo
26 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
