Question about 70 HP 4WD Tractor w/ Front End Loader Backhoe Agricultural Tires
Fiat tractor lift arms wont go down but will go up
Lift wont go down
Back lift arms on 100-90 fiat will go op but will go down very slowly
Posted on May 04, 2015
Rear link arms wont lift under load. what can I do to fix this?
you didn't mention make or model; rear links are hydraulic?
If so did your "mechanic" put a high pressure gauge on the ram hose(s) and see what pressure there was? Problem could be in controller for link.
Jun 06, 2015 | Garden
John deere 4040s back hydraulic problem lift arms wont lift and no back hydraulics
bad check vale or low fluid take to shop 100.00 for check valve
Sep 10, 2014 | Garden
How do i get wiper arm to go to edge of windshiels
At the bottom of the wiper arm lift the cover, you will see the nut that holds the wiper arm on just undo and wiggle the arm off replace about four splines up then refit, If not enough just undo again and move up another few splines.
Mar 16, 2013 | 2005 Fiat Punto 1.2
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Fitting a wing mirror on the passenger side of a fiat punto
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Apr 18, 2009 | 2006 Fiat 124
'07 5403 John Deere Tractor lift arm will not lower
some-times the 3pt linkage can go past the top position.
When this happens - you will need to force! the linkage arms down.
Apr 05, 2009 | John Deere 420,1020,2010,2020,2510,2520...
70 HP 4WD Tractor w/ Front End Loader Backhoe Agricultural Tires Logo
864 people viewed this question
Top 70 HP Sport & Outdoor - Others Experts
Are you a 70 HP Sport and Outdoor - Other Expert? Answer questions, earn points and help others
