Question about Pride Go Chair Travel Power Chair
Go chair wont drive
Go chair will not function
I want to thank you for the superb post!! I surely liked every bit of it. I've bookmarked your internet site so I can take a appear at the latest articles you post later on.
<a rel='nofollow' href="https://www.wheelchairindia.com/1194/Pride-Go-Chair">Pride Go Chair Travel Power Chair </a>
Posted on Mar 21, 2016
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
I replaced the battery charger with a quest charger, chair now charges but wont function i guess because of the inhibit feature how can i fix this
A few things to consider: A blown charger fuse can cause the charger inhibit to activate. Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
May 09, 2013 | Jet 3 Ultra Power Chair
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Apr 22, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
The power funtion drive on my Invacare Storm TDX 5 wheelchair, which operates the tilt, recline, elevating leg rest and seat elevator has stopped working. The drive switch as it appears on the LED screen...
1) Yes your power seat functions can be programed into your drive 4,You'll need a programmer or have to take it into a shop.
2) yes the chair can be manually elevated down,You'll want to take it to a shop for that ,because it requires jumping the power to the seat elevator and swapping the wires around and I would never recommend my customers to do such a thing because of electric shock or burning up the chair.
If your chair has a four wat toggle switch("what controls your power seat functions elev,recl,telt,ext) If thats what your using right now there may be a red light that comes on in drive lock out ,If that light is not on follow that wire all the way down it may have been pinched or cut.If so it will need to be replaced.
Problems like this one is hard to trouble shoot over text or phone ,if your four way switch cord is cut or smashed .Your gunna have to take it into a shop just to make sure ,It didnt cause any electrical problems in your chair .
Good luck hope i had the chair in front of me so i could help you more.
Jan 15, 2011 | Invacare Health & Beauty
When I switch on .all the lights sweep from green to red and chair wont function
Is the chair connected to the charger? If so, disconnect it then power the chair off then on again.
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Dec 27, 2010 | Invacare Supply Group Invacare Pronto M91...
Wont turn on light just flash back and forth on speed setting
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Sep 25, 2010 | Pride Mobility Products New Pride Mobility...
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I need a used/remanufactured 50 Amp VSI Controller for a Pride Go Chair
Search ebay, you'll find them new and used, and make sure that the connection into the chair matches up with your chair...most will send you a picture of it, and also make sure that the controller is programmed for RWD (Rear Wheel Drive), or you will also need to get a PP1 programmer to reset it for your chair. If it came off of any RWD chair and the connections are the same, it will work on your GO-GO.
Oct 26, 2009 | Pride Go Chair Travel Power Chair
Chair will move forward and backwards OK but either will not turn or will go around in a circle very sharply
one of the motors is bad or has bad connection. try raising the chair so the drive wheels are off the ground (free-wheel) turn power on, push joystick forward and watch for drive wheels to turn. the one that wont indicates a bad motor or connection.
Jul 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Pride Go Chair Travel Power Chair Logo
208 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
