Question about Royal ThermoSolutions Digital Wireless Thermometer Desktop Weather Statio
Manual for thermosolutions WS22
How do I deactivate the alarm?
How to desactivate only the hourly chimes alarm, in my taksun ts 613A
ask them. the manual doesn't appear to be available online.
Address :
Unit 9, 32/F., Cable TV Tower, No.9 Hoi Shing Rd., Tsuen Wan, N.T., Hong Kong
Tel :
852-2419 8831
Fax :
852-2408 1575 / 2409 0136
Contact Person :
Ms. JoJo Yeung
Email :
info@takshun.com.hk
URL :
http://www.takshun.com.hk
Oct 27, 2015 | Watches
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
I need an instrucion manual. royal thermosolutions WS44
how can get a manual for Royal WS44 inside/outside thermometer
Nov 16, 2010 | Royal ThermoSolutions Digital Wireless...
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
Aug 25, 2010 | SkyScan 31983 Clock Radio
How to deactivate car alarm?
I have not a car but my father has a car and i knew that m father went to the car and was stayed yto there until alarm was stoped crying
May 01, 2017 | 1998 Ford F150 Regular Cab
How do I deactivate my alarm system 2004 sxt envoy
Use your manual to identify the fuse for the alarm, then deactivate the alarm and put the key in the ACC position and remove the fuse. This does not always work, so i am posting it as a clarification request.
i hope it works for you,
matthew
Oct 22, 2009 | 2004 GMC Envoy
How do i deactivate the alarm on my samsung f480. i have tried to turn it off but it just turns itself back on
To deactivate an alarm:-
1. In idle mode, tap 'Menu' then tap 'Alarms'.
2. Tap the alarm you wish to deactivate.
3. Tap again to enter the alarm settings.
3. Tap 'Alarm activation' to highlight, then tap again to select to 'Off'
4. Tap 'Save'.
Aug 16, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Having a problem locating the alarm box
I had problems with an alarm. the ground wire was loose. i deactivated it by disconecting the ground wire. when i repaired the ground connection. it worked well.
May 19, 2008 | 1994 Chrysler LeBaron
Timex T307S alarms
quickly press alarm 1 button to deactivate it when the radio and everyday or mon-fri icons are gone the alarm is deactivated. do the same for alarm 2 button and the sd1-4 or buz icons disappear.
Aug 09, 2007 | Timex (T307S) Clock Radio
Royal ThermoSolutions Digital Wireless Thermometer Desktop Weather Statio Logo
245 people viewed this question
Top Royal Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Royal Measuring Tool and Sensor Expert? Answer questions, earn points and help others
