Question about Sole Fitness F63 Treadmill
Treadmill Elevation Error
I have a Sole F63 treadmill. It has been working fine for 2 years. But yesterday when I turned it on and inserted the safety key, the screen said "INITIAL", the platform started to rise then stopped. Then I got "ELEVATION ERROR" on the screen. It said to push "START" to bypass, but that doesn't lower the platform back down...nor do either set of "UP" "Down" buttons. I tried to reset the factory settings. It starts its test, the belt speeds up quickly for almost a minute or so, then I get "CHECK ERROR" on screen and then none of the buttons respond.
5 Suggested Answers
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
  • 33 Answers
SOURCE: Our Sole F63 treadmill is
pls make clear , countdown is come or not, if coming means problem with controller
Posted on Feb 19, 2011
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Sole F63
Test the flexible cable from keypanel vs display board and tigh the connector from display board vs main controll motor board. Test the relais if there are. Test for open and close, and clean the contact with spray for clean contact. Watch the videos. Finally the display board can be faulty b) main motor board too faulty.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedgood luck , sincerely God bless you.
E.CUADRA
MANAGUA, NICARAGUA
Sole f63 e4 error why
If you wish to get some details about treadmill error codes; check the site linked here. http://electro-medical.blogspot.com/
Nov 07, 2016 | Sole Fitness F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Treadmill Elevaton Error
There are a few things you may need to check. You already tried calibration. Next thing I would do is check the sensor wire from the incline to the controller. Make sure its properly plugged into the controller. The controller can also be an issue. If someone was tampering with the unit, the sensor wire could be plugged into the wrong connector as there is another connector that will fit. You may contact me for phone support or sign up for phone support at Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Mar 24, 2014 | Sole Fitness F63 Treadmill
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
Error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
Jul 08, 2012 | Sole Fitness F63 Treadmill
I have a Sole F63 treadmill and it came up with an elevation error. When I switch the unit on, there is a motor running and "Elevation Error, Press Stop to Bypass" is displayed on the screen. How...
E.CUADRA
MANAGUA, NICARAGUA
Sep 24, 2011 | Sole Fitness F63 Treadmill
My treadmill does not incline
incline motor has failed and needs replaced
Jul 17, 2010 | Sole Fitness F63 Treadmill
Sole Fitness F63 Treadmill Logo
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
