Question about GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
GE pfss6pkx refrigerator Side by side icemaker fills up with water, but doesnt push out the cubes. Why?
The icemaker fills up with water and freezes, but will not push the ice out after it's frozen. How can I trouble shoot this problem?
  • 1 more comment
  • jvanmill Mar 25, 2014
    I kind of figured it was part of the IM assembly, but im trying to fix it without replacing the entire unit. I've taken it apart and think it can only be a few things....yet without any experience with this type of unit...i don't know how to test it.
  • Fred Oakes
    Fred Oakes Mar 25, 2014
    The motor is the round part inside the cover. Once the ice is melted you can take out the motor and check the numbers to search for a replacement motor. They are less than $30 usually and are easy to put back into your unit. I suppose you could test your motor when the ice is gone to see if it can turn over the gears.
    I was able to clear out the ice and remove the motor. I manually turned the gears which turn the rake. Put it back together, let the system start and could visibly see the rake turn 360', the ice level arm drop down, then fill with water in the tray. After that when the water has frozen to ice cubes the rake will not move. I'm making an assumption and thinking a switch is not closing when it should or is closed when it should be open. Not sure how to test the switches? Any idea how, or where i can find a wiring schematic for my particular model?
    New Friend:
  • 13 Answers
It is the motor that drives the ice out and it can be replaced with a new one from online or just replace the complete icemaker for less than $150 or so if you check around the web. They are readily pulled out with just a few screws holding them in and the wiring is just a snap in process. Cheaper than a service call to just replace it.
Posted on Mar 25, 2014
  • Fred Oakes
Sea Breeze
  • 4655 Answers
SOURCE: GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Posted on Apr 21, 2009
aasc
  • 1606 Answers
SOURCE: Ice shoot freezes up
If you use a lot of crushed ice , then it will freeze up . Also if it does not open completely or close completely , the plunger and solenoid for the dispensor flap could be rusted .
Posted on Jul 19, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
  • 103 Answers
SOURCE: GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Posted on Oct 10, 2009
  • 4 Answers
SOURCE: My GE Profile side by side refrigerator is
Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment. Let us know what you find and we can go from there.
Posted on May 19, 2010
Will not drop cubes fills with water but does not rotate to push out cubes
first is it the ice maker that doesnt drop the cubes or the auger motor on the door you have to determine if your icemaker is droping the cubes into the bin if its not the replace the ice maker if it is replace the auger motor on the door you can find both of these parts at marcone hope this helps
May 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker works but either overflows or leaks into the freezer compartment and ice bin making the cubes freeze together. Valve appears to shut off when cycling, and will turn off and not leak when ice...
hello, my name is Marclavoris, i will fix your appliance for you.....okay understand that when your icemaker is on, it sends voltage to water valve, if the solenoid in water valve do not close it will fill the icemaker with water..So replace your water valve and your problem is solve...thanks
Nov 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I am unable to get ice. Cleared the tube.....arm on ice maker is down. I have a ge performance profile TFX22PP
Pour about 1/2 cup of water into the icemaker . If it dumps the cubes after freezing , replace the water inlet valve . If it holds the frozen cubes and does not dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc ...
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Icemaker auger jams , GE side by side
Water expands when it freezes and you probably have too much of it when the mold tray fills... Readjust the level to a bit less and you won't have triplet or quadruplet ice cubes..
Hope that helps...
Aug 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
