Question about Frigidaire FGHD2465NF Built In Dishwashers
Frigidaire FGHD2465NF leak from the bottom by motor
Leak from the bottom by motor
My frigidaire gallery french door with ice maker is making a knocking noise every 5 seconds. Sounds like from the ice maker. How do I fix or stop the noise.
I have a different type. I rubber banded the little ARM in the UP position ( to fool the unit that I have enough ice). NO MORE SOUND>>
Jun 03, 2015 | Frigidaire FGHB2866PF3PCKIT Gallery...
What do I adjust to prevent the door from opening too fast? When I open the dishwasher door I must hold it so it does not come down too fast
Herbert,
You probably have a broken door spring or a hing cable. I looked your model up on Sears parts direct and have included a link. You are looking for item #1 or #1A. Good luck! http www searspartsdirect com frigidaire dishwasher parts model...
Apr 07, 2015 | Frigidaire Gallery FGHD2465NF Fully...
Frigidaire dishwasher won't derail
what rail is it supposed to be on? Do you mean won't drain?
Mar 04, 2015 | Frigidaire Dishwashers
Why am I getting an error code iCO on my frigidaire gallery dishwasher?
I just addressed a iCO error code on my 2 week old Frigidaire Gallery DW. I reset the circuit breaker as recommended online and it worked fine for another few days and then came back. Customer service cannot tell me what the error code means. They WILL NOT replace the DW, rather want to schedule a service appointment. I have no desire to repair a new DW so I am receiving a refund from the retailer I purchased from. On to the next brand!
Aug 18, 2014 | Frigidaire Gallery FGHD2465NF Fully...
FFHB2740PS
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jun 20, 2014 | Frigidaire FFHB2740PSKIT2 FFHB2740PS 26.7...
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Frigidaire built in dishwasher leaking water out of the bottom.
One of the reasons could be door seal or sump seal leaking. But if the leak only occurs at a particular time in the cycle then most likely the wash motor or drain motor seals.
Need the model number to make a more closer assessment.
Dec 31, 2012 | Frigidaire Dishwashers
I press start the water fills fine as soon as it start running i get a loud humming/ vibration and nothing happens?
sounds like the motor is bad.after it fills the motor should start,has it been leaking under the bottom of d.w.rmove the bottom front panel and see if there's any water stains,usually the motor will leak before it finally dies.
Apr 01, 2011 | Frigidaire Dishwashers
Frigidaire FGHD2465NF Built In Dishwashers Logo
49 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
