Question about Whirlpool Dishwashers
Whirlpool dishwasher gu1500xtls3 control panel not working
The heating element broke and I have replaced it but now the left side of my control panel to start my dishwasher will not light up and am unable to start my dishwasher
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
Not heat when washing
replace heating element
Apr 07, 2015 | Whirlpool Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 22, 2013 | Dishwashers
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
We have a Whirlpool dish washer gu1500xt not sure how old it is. Problem nat cleaning was well sometime we find soap despencer open with the soap cake on it. Also finding left over dirt near the top right...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 05, 2011 | Whirlpool 24 in. GU1500XT - Multiple Color...
My whirlpool ADG 7540 dishwasher is not heating the water but is running through the programme
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
I currently have a whirlpool with a flashing green
I can't locate your model number, it may only be a partial number and/or missing a couple of digits or letters. Fortunately with most "Whirlpool" built dishwashers...
This is actually a built in "fault code" of your dishwasher. It could mean you have a faulty control, but not very likely. Here's a couple of things it commonly means.
1) the heater has failed/opened, so the control sensed too long of a heat cycle.
2) a wire from the element has come off, (it happens just from normal use and vibration at times) so the control senses the same fault as a "open" / defective element.
3) your wash motor&pump assembly has become seized or jammed to the point it cannot circulate the water to heat sufficiently, or heat in the acceptable time table.
Here's what you can do to check.
on the control you'll need to activate 2 buttons in sequence back and forth. The 2 buttons will be "heated dry" and "air dry". push those 2 buttons in this sequence, heated dry-air dry, heated dry-air dry.
This should activate a short "test" of the component's, i.e. water valve, detergent dispenser, wash motor, and finally drain. Try to make a note if the wash motor runs, or just "hums"/ "buzzes".
This test should also reset the control to eliminate the illuminated clean light. However, the light will continue to return until the cause is found and remedied...
...now to find the cause, **disconnect the power, shut off the breaker**
You can visually inspect the element in the tub. Does it have any "burn marks" or any holes ? No ? OK, undo the 2 screws at the bottom of the unit, commonly refered to as a "toe panel" or "kick plate", it is the access panel for servicing the unit. The panel should be easy to remove once the screws are out. (you may actually see a service sheet or tech sheet in a plastic envelope on the back of this panel. If you use it, do all us technicians a favour and put it back, lol). with the panel now out of your way, with the aid of a flashlight, look to the very back of the dishwasher. You're looking for any wires that may be disconnected, specifically a white colour wire with a purple/violet tracer on the left side of the element and a red wire on the right side connection. (don't get too hung up if the right side isn't red, it could be brown or even orange in some cases, red is just the most common by far).
If the connections are good and the wash motor & pump work, now with the aid of a multi-meter, ohm out the element.
It is possible it is defective without any visual evidence, but the meter won't lie. If you have continuity,(the needle/numbers moves) it's good. If not,(needle/numbers doesn't move) it's bad.
...the remedy, if you can rule out a loose/disconnected wire, should be obvious at this point. Either a burnt out element needs to be replaced or a bad wash motor & pump assembly has to be replaced.
hope that helps, let me know. good luck.
macmarkus :)
Nov 05, 2009 | Whirlpool Dishwashers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Apr 20, 2009 | Whirlpool LEQ9858L Electric Dryer
The element in my whirlpool dishwasher does not heat what can the problem be
Ok, there is an electric thermal fuse located on the back of the control panel inside the top part of the door. you will have to disassemble the top part of the door to get to this fuse. its integrated into the control board. replacing this fuse with give the element power once more. if the element doesn't work after you replace this fuse, its because the element itself is damaged and will need to be replaced.
please rate this response and god bless..
Mar 17, 2009 | Dishwashers
Whirlpool let7848dqo no heat
Check the thermal fuse it is on the left side of the heating element duct up about 3/4 of the way has 2 wires you can jumper it out if it heats you can buy the kit part# 279816 let me know if this does not work we can look elsewhere
Nov 30, 2007 | Whirlpool LER5636P Electric Dryer
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
