Question about Philips 996510006936 T-Con Board T420HW01 V2, 07A33-1A
NEGATIVE PICTURE STRONG COLORSLIKE
NEGATIVE PICTURE
Negative picture when filming
I found the home website for your camera on sony.com's european website:
http://support.sony-europe.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV140E
I didn't see anything about a negative picture on screen when filming, though.
Good luck on finding a solution to your problem.
Jul 18, 2010 | Sony Handycam DCR-TRV140E Digital...
Negative effect on Bright areas of Monitor/TV
Try demagitizing the moniter. In the monitor's menu it will have a picture of a magnic , select it. Sometimes it is listed as degrous. After selecting this, your screen will seem to spin then settle. If your still have problems, a magnic may have come close to the moniter while it was being stored, and that will ruin the picture.
Sep 21, 2009 | Computers & Internet
The audio cuts in and out intermittently
IT COULD BE ONE OF UR SPEAKER WIRE A TOUCHING AND GROUNDING OUT LOOK AT UR SPEAKER. AND IT COULD BE ONE OF UR SPEAKERS IS CONNECTED WRONG WITH THE POSITIVE ON THE NEGATIVE CHECK THAT OUT TOO ALL SPEAKERS NEED TO BE POITIVE WITH POSITIVE AND NEGATIVE WITH NEGATIVE
Jul 04, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Power mac 8200 battery refit - which way round?
figure it out well, notice your main-board, the battery slot has a negative (-) and positive (+) mark, though it isn't noticeable but it has, then see your battery, when you're going to attach it to ***********-board, it should be (+) positive to positive (+) then (-) negative to negative (-)
Dec 13, 2008 | Computers & Internet
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Jump start 2000 venture
In order to reach the negative terminal to the battery in a 2000 Vebture (I have one) you must first remove the fuse housing. The fuse housing is a large black box that sits atop the battery. There os a single bolt that holds it in place located in fron of the battery bolted into the lip of the motor bay. Unscrew this, then unhook the fuse housing from the cross bar running from the back roght to the front of the motor bay. This is a tight fit so watch your knuckles. Once the fuse housing is out, the negative terminal is located on the backside of the battery. It is a tight squeeze black is negative, red is positive.
Oct 06, 2008 | 2000 Chevrolet Venture
Negatives to pictures
The manual didn't show negative and slide support. I recommend you some of the hp products like HP Photosmart C7180 All-in-One, HP Scanjet G3010, HP Scanjet G4010, etc.
Feb 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Philips 996510006936 T-Con Board T420HW01 V2, 07A33-1A Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
