Question about Pentax Optio 50 Digital Camera
Lcd not working, screen is dark
Camera turns on but screen only shows setting but no pictures
In my w180 image is clear and bright in the LCD screen but when i downloaded the images to my PC it shows poor lighting and dark images pls help me
The lcd screen on your camera is back-lit and shows a brighter picture than the one you actually take. If you can turn down the screen brightness that may help. You could also raise the "exposure compensation" setting and experiment until you find a setting you like.
Oct 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dark screen when I turn on the camera and take pictures.
It looks like the LCD backlight malfunction. Check the backlight voltage, if you have the voltage there, you need to replace the LCD unit, otherwise the main board is defective.
Aug 03, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
LCD screen is very dark, Pictures taken are underexposed
If the pictures show up normal on the computer then the back light for the LCD is going bad.
Apr 05, 2009 | Canon PowerShot A640 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Sep 04, 2007 | Logitech ClickSmart 420 Digital Camera
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Pentax Optio 50 Digital Camera Logo
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
