Question about Arctic Cat Winter Sports
Charging system problem 1994 pant era
Charge lite comes on intermittently and then the battery goes dead and efi will not work properly
    Champion:
    New Friend:
  • 220 Answers
Sounds like you have a short in your wireing harness. Look by the brake caliper.,also make sure the voltage regulator is tight.
Posted on Sep 29, 2014
My sons1999 Jeep Grand Cherokee had the gauges light on and would not start like battery was dead. Had it jump started and it started.When he put in park it stalled jumped again and worked.
Sounds like a charging system problem and the alternator may not be working. The gauge light will come on if the charging gauge is showing low so you will look at the gauges. Have the battery and charging system tested
Jan 05, 2016 | 1999 Jeep Grand Cherokee
I have a 1993 arctic cat 700 efi that the battery keeps going dead in how do I check if its charging?
When a battery dies while the engine is running it is not being charged. When the charger is working the engine will run without a battery
Dec 13, 2014 | ATVs
Fix 1997 cadillac deville concours charging system
Charging voltage should be around 14 volts or more for battery to be properly charged. If significantly below that the alternator is not working properly.
Sep 05, 2017 | 1997 Cadillac DeVille
Charger lite will not come on! there is power to charger and if you wiggle lite the charge lite will blink but not stay on
It sounds like the battery is completely dead. Try placing it in the freezer for a couple of hours and attempt to charge it. If that doesn't work, you will need to know the make a model of the flashlight it goes in as well as the voltage. If you have to purchase a new battery I would suggest you purchase a Nickel-Metal Hydride (NiMH). NiMH's have much higher capacity than NiCd's and don't suffer from memory effect.
May 20, 2010 | Streamlight Ultrastinger Rechargeable...
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
Turns on screen comes on and goes straight off
This is exactly what happens when either; A: your Ds lite's battery is dead, or B: your battery is worn out. If your Ds lite still does the same thing after you have let the battery FULLY charge before using it, then your battery is most likely the problem. If this is the case, then you need to buy a new battery, which is between $6 - $10 at some places. When you get your new battery (if you buy one), you need to first let the Ds lite charge COMPLETELY before use, and then after that let it fully (or at least mostly) die before charging it again. If you constantly charge it when it is half or mostly full, then than will MAJORLY shorten the battery life, and eventually cause the problem you described. You need to take care of the battery or it wont last very long.
Feb 07, 2010 | Nintendo DS Lite Console
Battery goes dead intermittently
Quite often the alarm system ends up being the culprit. If you have, or know someone, who has a clamp on amp gauge that can test the draw from that circuit, it should tell you what you need to know. It could be that or a combination of various draws from your system.
Mar 22, 2009 | 2004 Cadillac CTS
1994 Saturn will not start intermittently.
mybe the batt. has a dead cell change the batt.
Nov 30, 2008 | 1994 Saturn Sl
Winter Sports Logo
296 people viewed this question
Top Arctic Cat Winter Sports Experts
ka4iup
ka4iup
Arnie Burke
Arnie Burke
ray gallant
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
