Question about Refrigerators
Hi i have a hitachi R-M700GG8 it keeps on displaying F0 12 on my screen what does that mean?
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
42pd300ta tv plazma hitachi screen got blurred
Do you mean a display trouble? Check this link, and make sure that the display panel to your TV is not faulty. One among the post in the link have over 150 screen shots to different faults to Plasma display panel. Compare them to that of your TVs display screen, and make sure that there is no panel problem. Pull up older posts there, http://electronicshelponline.blogspot.com/ either by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Televison & Video
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
I have a HITACHI-AXM898U-Micro-Hi-Fi. The display screen has just stopped working. can you help me?
This one of the more difficult problems to locate, check display for cracked solder joints, overheated parts, open foil, or the backlight has failed.
Mar 16, 2012 | Audio Players & Recorders
hi my hitachi fridge is giving error fo 12 what happend with this
Jan 30, 2011 | Refrigerators
Fly back lines
the unit is stating an impending breakdown in the horizontal circuit.bring it to a tech to for further analysis.
May 20, 2009 | Hitachi 27FX49B 27" TV
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
When I turn on the camera "media error" is displayed on the screen. The card is OK I have tested it in anoother camera. Hitachi hdc-1251e
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 19, 2008 | Hitachi Cameras
Screen Width Adjustment
Hi there
Try lifting up the Projector or lowering it. If it shows ok then , you'll know what to do . See it all depends on the height of your screen and the height at wich you are Projecting at.
Also check if this Projector has three places at the bottom for screws to go in , which would make it's lens even worse because these type of Projectors are actually made to be mounted upside down.
If you flip the Projector upside down whilst on , you'll see what I mean.The angling is made for it to be upside down.
Hope this is of help
Apr 02, 2008 | Hitachi CP-X980 Multimedia Projector
Hitachi CPX275 unstable connection with Vista
Pls set up the display properties to screen reslution to 800x600 and then try higher resultion. that will work.
Viren
Jul 31, 2007 | Hitachi PJTX100 Multimedia Projector
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
