Question about Hitachi KNR90AE Round Head Framing Combo Kit With Compressor, Nail Gun and Hose
Misfires new gun
Stops after 50 nails
    Sergeant:
  • 233 Answers
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Posted on Mar 29, 2014
How do I fix a pneumatic finish nailer that won't feed nails from the magazine
Does the tool stop firing at about the same point on the magazine every time? It could be there's either some blockage that you can't see in the mag or, that the mag has worn down. If the latter is the case, replace the magazine frame.
Sep 20, 2014 | Tools & Hardware - Others
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
NO NAIL IS COMING OUT WEN YOU PRES THE TRIKER
I presume the gun fires but no nail is ejected. A possibility is jammed nails in the magazine. Do you see a mark in your work piece of the driver blade? If yes then it is most likely jammed nails. If not could be a broken driver blade. If gun does not fire could be gas problem. (check in date, yes it does have a use by date), another cause of not firing is a broken wire particularly around trigger switch (switch is on trigger and hence the wires are flexing every time trigger is pressed). Another cause of not firing is a brass spring clip in handle assy if this breaks it stops the gun firing. Recently I have had more broken wires than anything else on these guns. Worth noting is that the Stanley Bostitch nail guns suffer the very same faults. Also note they are the same gun just different colours so you can fit Hitachi parts to the Bostitch and they are cheaper.
Feb 12, 2014 | Tools & Hardware - Others
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
My Senco 700XL Nail gun misfires a lot!
The 700XL is a good gun worth repairing and fairly easy to work on. You should be looking for two Senco rebuild kits, part number YK0243 for the top end and YK0244 for the bottom end. After installing all the parts from these kits you'll have a brand new gun. To take it apart, remove the four screws holding the head cap on. Keep track of how everything comes out so you get back together the same way, the kits have good instructions to get all the right o-rings in the right places. The o-rings on the long skinny trigger valve are hard to get off and on but they will stretch enough to do so. Use the assembly lube liberally on all o-rings. The center piece in the cap can be pried out gently with a screwdriver and is hard to get back in but make sure it is fully seated and straight in the cap when you put it back together.
Mar 19, 2012 | Senco Air Tools & Compressors
Paslode misfire
not sure what this is by your description but here is a link to a forum that talks about paslode missfire nailing gun. hope this iw what your trying to fix? to ask questions you will have to joing the forum. Paslode Cordless Framing Owners Fix For Misfires
Nov 03, 2017 | Air Tools & Compressors
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
My N12 stops feeding after every 2 or 3 nail.
could be a few problems, are you using the right nails with the proper collation. is the magazine set correctly for the nail size, is the piston retracting fully to advance the next nail, and is the feed pawl spring broken and or is the feed pawl moving freely, to check the last one remove all nails and open the door that would guide the nails and fire the tool and look at the feed mechanism to make sure working properly, sometimes the bumper starts to disintegrate and pieces get stuck in the air hole controlling the feed. Let me know if you need more clarification or help
Nov 29, 2010 | Stanley Bostitch N12 Coil Nailer...
Hitachi KNR90AE Round Head Framing Combo Kit With Compressor, Nail Gun and Hose Logo
212 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
