Question about Brother P-Touch QL-1050 PC Label Printer
Cutting one at a time
Need to cut after labels are done
2 Suggested Answers
SOURCE: spits out label but cuts words off
Problem is solved by pressing the function key until "margin" comes up. Then press function key again while "margin" is selected. Use the arrow key to select the "###". Then once that is selected press the function key again. That solved the same problem I had. Good Luck :)
Posted on May 09, 2007
The top portion of the word and or number is cut off on the label. Other wording is fine on the label. Zebra ZM 400
please send me photo to paulr@Rocotech.com.au and I will help you to sort the issue. regards. Paulo
Mar 02, 2015 | Zebra ZM400 Thermal Label Printer -...
My only problem so far is trying to get the backing off the label so I can stick the label where I want it.... is there a trick to this?
when you have cut the label slightly push together on one end as if you were folding it in half as there is a cut in the backing paper which will allow you to pull half of the backing paper off at a time
Apr 28, 2011 | Dymo LetraTAG Thermal Label Printer
Where can I get a speaker connector?
After a few hours of looking on line and finding nothing I decided to make my own Sharp Receiver connectors. Here are the steps that I took:
_1349.jpgItems I used were wire strippers, wire snips, a file and a sugar free Rockstar (not pictured items: computer power supply, fine grit sandpaper and zip-ties).
_1350.jpg The first this I did was find the 4 pin connector and the 20 pin connector (some times a 16 pin) on the pc power supply and i cut the wires so that there was about 10" to 12" of wire hanging from each connector. These are the 2 connectors need from the power supply to use in your Sharp Receiver.
_1351.jpg This is the smaller of the 2 connectors (the 4 pin) and nothing needs to be done with this one. It fits perfectly into the back of the Sharp Receiver into the area labeled " surround sound". I would just zip tie the wires 3" from the connector and then 6" from the connector.
_1352.jpg The large connector I cut from the pc power supply is the one where all the work needs to be done. The Sharp Receiver requires an 8 pin connector for the are labeled "front speakers/center speakers/sub woofer". Notice the location of the clip for this connector and that it is centered, we need this clip to remain in the center when we are done so re are going to have to remove every thing from it except for the center 8 pins.
_1353.jpg What I did to get the connector to look like this picture is I cut the 6 pins off on both ends of the connector (you would only cut the 4 pins off both end if you are using a 16 pin connector from the power supply). after I cut those pins off I just pulled the wires out from the back side (they come out very easy after you cut the pins off). Now we need to get rid of the extra plastic where we cut the pins. Please view the next 2 pictures before you begin to do your cut.
_1355.jpg Notice how I left the plastic intact surrounding the 8 remaining pins we are using. I know that it seems like common sense to do it this way but there's people out there who would have cut the plastic so the pins we need are showing. There may be some jagged edged now from where u cut the extra plastic so to get rid of that we are going to use a file or a grinder. Don't grind the sides completely down though, I left a little bit of the ridges because the new ends have thin plastic walls and if you leave a little of the ridges, it will make it a little stronger.
_1356.jpg I tried to put my, now 8 pin, connector in the back of my Sharp Receiver and it was really snug. This is where the fine grit sandpaper comes in handy. just go around each of the 8 pins with the sandpaper, not a lot, just enough so the pins slide into the plug easy and doesn't wiggle. I used 2 zip-ties on this connector also to secure the wired a little more. Again, 3" and 6" from the connector. Now its ready to be plugged into the area labeled "front speakers/center speakers/sub woofer".
_1357.jpg This is what it should look like when you are all done making the speaker connectors for your Sharp Receiver. All that's left is to connect your speaker wires to your speaker connectors and then all of your components.
I only found 1 website that had the parts for this unit for sale and it was about $50 plus shipping for the connectors. You can get the computer power supply from your local area on www.craigslist.org for $5 or $10, you might have one lying around. If you have any questions or need additional help with this please feel free to email me: jlusk80 @ gmail.com
Thanks for reading my solution!
Jan 01, 2011 | Sharp HT-DP3000 System
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
We have a zebra lp2844 and it cuts the labels off on the righthand side where the bar code is cut off. is there a way to center the label ? any help would be apreciated! thanks.
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default which should use the top of form and label dimensions to print in center. If not....I need more info - what type of software are you using?
Aug 04, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Brother P-Touch QL-1050 PC Label Printer Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
