Question about EliteGroup Computers & Internet
Dead battery battery will hold a charge
Lifefitness recumbent bike battery not charging
Possible causes for a dead battery or it not holding charge
1. Battery has lost its ability to hold a charge (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
For any further troubleshooting you can contact our Technical Support Team and we would be happy to help you,
online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Aug 16, 2014 | Life Fitness 9500 HR Recumbent Bike Next...
3300CE charging problems
The battery on my unit is dead. What could be the cause? Possible causes for a dead battery on battery operated units: 1. Battery has lost its ability to hold a charge
The battery on my unit is dead What could be the cause
Jan 14, 2014 | Stairmaster Exercise & Fitness
Charging camera
I think that your batteries may have expired due to old age and are refusing to hold a charge.
Ni cad batteries have a shelf life and once that time limit has expired, you need to replace the batteries with new ones which will begin counting down to their expire date and also go dead.
once ni cad batteries have expired and past their time limit
nothing can be done to revive them ,they are forevermore dead and must be replaced.
that is the reason why i buy 120 volt ac drills instead of battery powered drills which are always dead by the time i need to use them and wont hold a charge when i try to recharge them.
my cordless radio phone batteries go dead after 1 hour on the phone, when they were newer,i could talk for 4 hours and still have 1/4 charge left. soon they will only last 30 minutes and need a 12 hour recharge to come back to 4 bars.
so i expect to have to pay 4 new batteries by christmas.
One other option may be that your charger is not working properly and developing the required voltage.
that also happens but not as often as dead batteries that wont hold a charge.
if you have a radio shack nearby, even if its a 20 mile drive
they can test your batteries and also test your battery charger. just ask for a salesman that has a battery tester and a vom [volt,ohm,milli amp meter] also called a multi meter. The vom will test your charger and came also test your batteries, but most salesmen dont know enough about the vom to use it as a battery tester .
PS a battery tester is just a vom scaled down for battery testing only, made easy to use for dummies.
Oct 09, 2013 | Pentax Optio Cameras
My dodge dakota will not idle and the battery keeps going dead
The problem with a lot of dodges is that the computer will loose the idle memory when battery power is lost, to regain the idle just hold the gas pedal a little to keep engine running for about 2-3 min then release the pedal and it will idle on its own, if the battery goes dead it will loose idle again.
As far as the battery going dead you will need to check a few things, first have the battery tested a bad battery that doesnt hold a charge can test good and still be bad due to it can not hold a charge. the battery is charged and if it tests good try this, unhook one battery terminal over night or for as long as it takes to drain normally. if the battery goes dead unhooked then the battery is your problem.
At the same time the battery is tested have the alternator tested. Make sure its tested good. what i mean is tested at idle with all acc on, like lights heater, rear defoger and etc.
Hope this helps. good day
Sep 25, 2011 | Cars & Trucks
I left the ignition on and the battery went dead. now the battery wont hold a charge. i can charge overnight starts right away. ride for 30 mins. turn off and it wont restart.
Is this an acid batter? If so you may need to add water to the appropriate levels for it to hold a charge after you put it on a trickle charger. Otherwise, I would say the battery is dead and you need to replace. Good luck!
Jul 30, 2011 | Yamaha XS 400 SE Motorcycles
The battery wont hold a charge. the battery is completly dead after a very short period of time
Does the battery go dead while sitting or while driving? You may have a draw problem where something is draining the battery while parked, or you may have a charging problem, or you may have a bad battery, depending on how it goes dead.
Jun 18, 2011 | Chevrolet Impala Cars & Trucks
Amcor 3500 will not turn on went dead, what could be wrong ?
Could be a bad connection where the power supply plugs into the gps or it could be a dead battery, or one that no longer will hold a charge. When this happens the gps unit will most often fail to power up. Check the battery and if it is dead and won't hold a charge, then change the battery. This should then clear up the problem. Hope this helps
Jun 11, 2010 | Amcor Amigo 3500 GPS Receiver
My battery will not hold a charge, Even when plugged into the charger. What do I do to fix it?
I suggest you remove the battery and put it in a similar phone and charge with your charger to see if it will hold charge.
If it does, i means the battery is still good. but if it does not, it means the battery cell is dead and the battery will need to be replaced.
The problem could also be the charging port of your phone, it may be bad and not charging your phone but if it is charging it, it means the cell of your battery is dead and will need to be replace.
Just check the battery, charging port or the charger, one of either of this three is bad.
Take care
Apr 20, 2010 | Nextel i860
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
Battery won't hold charge - fine for 4 hours or so then dead
need to check battery and charging system with tester sounds like possibility of a bad charging system, alt or voltage regulater or bad connections
Feb 18, 2009 | 1992 BMW 5 Series
Computers & Internet Logo
20 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
